my ac blow hot air, anybody know that the problem is ? |
Jun 1, 2003 - 12:20 PM |
Enthusiast Joined May 2, '03 Currently Offline Reputation: 0 (0%) |
my ac blows in hot air when i crank it to max cold and full blast
it still blows in hot air for ten mins past and then i take it out for a spin and it still blows in hot air anybody know whats wrong ? |
Jun 1, 2003 - 12:41 PM |
Enthusiast Joined Apr 20, '03 From Chicago Currently Offline Reputation: 0 (0%) |
Your AC compressor might be broken, anyway it sure seems like it's something you need to get replaced.
Jun 2, 2003 - 4:47 AM |
Enthusiast Joined Nov 8, '02 From Narragansett,RI Currently Offline Reputation: 0 (0%) |
My temperature was not working right before and it was because the valve wasn't opening and closing correctly. There's a wire that pushes and pulls the valve open and closed that runs from the back of the heat controls to the engine compartment. What I did is that I went behind the controls and there was a little clip that held the wire in place that I just simply snapped right back into place. It was just as simple as that. I hope I could help.
Jun 2, 2003 - 4:56 AM |
your ac need juice..
Jun 2, 2003 - 10:38 AM |
Enthusiast Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
You probably have a leak somewhere. You have to go to a shop and they'll pour this dye into the system to find the leak. Fix the leak and get your ac recharged. Depending on where the leak is, it could be a cheap fix or an expensive fix.
Jun 2, 2003 - 11:21 AM |
ya i guess i have to take it to the shop and get it updated
thx u guys |
Lo-Fi Version | Time is now: December 1st, 2024 - 5:11 AM |
