> 4a-ge(20 valve)silvertop swap
post Mar 21, 2006 - 11:54 PM
Heytalktoryan
Joined Dec 13, '05
From spring texas
well after getting hit and run my idea for the beams motor went down the drain, i figred while its in the shop i might as wel get it swapped w/ the 4age 20 valve silvertop,anyways my question is how much do these swaps tend to run? and where can i find a 4age silvertop engine?oh yeah and time is a problem too the swap cant any longer than a couple of weeks.I basically just want to know whatt i would need?(clip or engine better?dont see the point in the clip since its a celica not a corolla) for the swap and what all neeeds to be done.i loooked around but couldnt seem to find anything:( anyways thanks in advance
post Mar 22, 2006 - 12:19 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
http://www.toyotacelicaonline.com/celica1/7ahybrid.htm|
great information on the swap there.
post Mar 22, 2006 - 12:22 AM
purplegt4
Joined Feb 7, '03
From Northern Virginia
post Mar 22, 2006 - 1:02 AM
Xpander
Joined Sep 5, '02
From Winter Haven, FL
This should probably be in the Engine/Transmission/Maintainence forum.
Anyways, your best bet is to get a clip. Forget about the body panels, most won't come with them and if they do you will end up paying more for it. With a clip you are getting exactly what you need, and sometimes extra aftermarket parts. If you were to get a motor set, you might not get certain parts to make your swap more complete (like the exhaust down pipe with the flex section) Other than the engine, you will need the Air Flow Meter, Ignitor & Coil, and complete wiring harness with ECU.
The prices of the motors range from $350-1000, with the clips from $1500-2000 (they are everywhere on Ebay). Just be sure to check what all comes with what you purchase. It might be easier for you to purchase a clip and do a basic swap or just get a motor and run a stand-alone engine management system. Its really what you can afford that will determine what you get.
www.club4ag.com is a great source of info.
I imagine you could get everything done quickly provided you can do the wiring or pay someone to do it for you fast, and get all your parts together ahead of time. Although it will probably take longer than what your timeframe will allow.
If you have any questions, send me a PM and I will help you as best I can. Good luck.
-Colin
post Mar 22, 2006 - 1:23 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
I on the other hand think this swap is common enough amougst the Corolla folk that you don't *need* to buy a clip... but it's nice to have one. The coil and ignitor can be sourced from different cars... along with all of the needed plugs for wiring. The only real parts you need, is the engine itself with neccesary attachments (dizzy, manifolds, etc)... and the ecu.
post Mar 22, 2006 - 7:58 AM
Heytalktoryan
Joined Dec 13, '05
From spring texas
QUOTE(Kwanza26 @ Mar 22, 2006 - 1:23 AM) [snapback]411240[/snapback]
yeah this is what i was hoping, i can probably have more time like maybe a few more weeks but it is my daily driver so i cant have it being out more than month, and as for the 7age route, i looked into that and i kind of wasent feeling it, ym current motor was swapped in w/ 80k and now i have no idea how much it has..more than likely around 85-87, but thanks for all your help smile.gif
what are common problems with running this setup? i read that i could use my stock st tranny w/ the 4a-ge, this is true right? but yeah liek i said before thnaks
post Mar 22, 2006 - 8:05 AM
Heytalktoryan
Joined Dec 13, '05
From spring texas
http://cgi.ebay.com/ebaymotors/Toyota-Celi...1QQcmdZViewItem this si what ive found...comes with the ecu alt ,ps,sensors and manifolds..lmk
also i found this are the black tops easier to swap in??http://cgi.ebay.com/ebaymotors/JDM-4AGE-BLACK-TOP-20-VALVE-1990-1996-COROLLA-ENGINE-TR_W0QQitemZ8046912152QQcategoryZ33615QQrdZ1QQcmdZViewItem
This post has been edited by Heytalktoryan: Mar 22, 2006 - 8:09 AM
post Mar 22, 2006 - 9:02 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Yeah the silvertop swap in the Celica ST isn't bad at all, there's a few out there, I know because I did the wiring harnesses for them smile.gif
Anyway, yes, you can use the stock 7A tranny. The blacktop is not really easier or harder to swap, but it's newer and more expensive... and more powerful.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Mar 22, 2006 - 9:28 AM
Heytalktoryan
Joined Dec 13, '05
From spring texas
QUOTE(Dr_Tweak @ Mar 22, 2006 - 9:02 AM) [snapback]411345[/snapback]
-Doc
yeah thats probably the route that ill end up taking..thnaks for everyyones help..oh and any idea on total cost of the swap?
post Mar 22, 2006 - 10:46 AM
Bitter
Joined Mar 11, '06
what kind of power do the silver and black top swaps make?
post Mar 22, 2006 - 11:57 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Silvertop has 160HP and Blacktop has 180 I think.
**** Photobucket
post Mar 22, 2006 - 12:35 PM
QUOTE(95CelicaST @ Mar 22, 2006 - 8:57 AM) [snapback]411416[/snapback]
Silvertops are rated at 160 and blacktops 165. But the silvertop tends to be over-rated when it comes to horsepower figures.
post Mar 22, 2006 - 1:37 PM
Bitter
Joined Mar 11, '06
are those stock engine numbers or average post-swap numbers?
post Mar 22, 2006 - 2:16 PM
95CelicaST
Joined Feb 5, '05
That is stock horsepower.
**** Photobucket
post Mar 22, 2006 - 2:29 PM
Bitter
Joined Mar 11, '06
so what kind of power is being put down post swap?
post Mar 22, 2006 - 4:00 PM
Dr_Tweak
Joined Mar 31, '04
I think the silvertops see around 130 whp.
Typically that swap into a Celica, including labor, costs around $4000 or so.
-Doc
post Mar 22, 2006 - 4:20 PM
Bitter
Joined Mar 11, '06
QUOTE(Dr_Tweak @ Mar 22, 2006 - 4:00 PM) [snapback]411508[/snapback]
-Doc
nm, whp. i didnt read! thats not to bad then considering a stock 7afe makes about 110-115 hp at the crank. i'd be happy to see 85 at the wheels with my auto and stock motor.
This post has been edited by Bitter: Mar 22, 2006 - 4:20 PM
post Mar 28, 2006 - 7:19 PM
Jeremiah
Joined Mar 19, '06
From Rocklin, CA
For what it's worth, I've acutally heard people complain after doing this swap. The engine makes more power in top end, but not for "normal" driving. Both engines make good power for what they are, but they're act very different, so make shure you're getting the one that matches your driving style.
The 4a-ge is a de-stroked version of our 7afe (1.6L vs our 1.8L), so they're noticibly less powerful in the low - mid range RPM (where we do MOST of our driving). The 4age has a VVT head, which is why it makes more HP, but it's at a much higher RPM. The end result being a car that will accellerate better once it reaches it's high RPM powerband, but feel less powerful during normal driving.
There's a 3rd option - a supercharged version of the 4age (forget the name) which makes much better power early on.
Just thought you should be aware before acutally doing your swap.
post Mar 28, 2006 - 7:36 PM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
you mean the 4agze. anywho... yeah, you have to rev higher to feel the torque with a 4age. but i don't think it accelerates slower than the 7afe in the lower rpm. i haven't heard anyone complain after replacing their 110 hp engine with a 160 hp one.
post Mar 28, 2006 - 7:48 PM
Jeremiah
Joined Mar 19, '06
From Rocklin, CA
QUOTE(j0e_p3t @ Mar 28, 2006 - 7:36 PM) [snapback]414775[/snapback]
Yeah, the 4agze was the supercharged one - thanks!
I've read the "complaints" on a 4age forrum (something like club4age.com?). Most those guys were interested in speed and racing, so they gladly gave up "daily driving" feel for MUCH better acceleration. I probably should have been more clear - I think the 4age swap sounds great - I've even considered it myself (I have a ST, so would be an easy swap) for when my 1.8L gives out smile.gif Just wanted to throw out there that it does act different than our ST motor.
You could put the 4age head on your 7afe block and have the best of both worlds. Probably as powerful as you can get with a natrually aspired 1.8L wink.gif
Lo-Fi Version Time is now: December 1st, 2024 - 8:29 PM
