2 Pages V  < 1 2
> 4a-ge(20 valve)silvertop swap
post Mar 29, 2006 - 8:08 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Yeah it's true, I've done quite a few silvertop swaps, just finished one yesterday and took it for a ride. It's an auto and I was comparing it against my '94 Celica ST auto. There's definetly a lack of torque at the bottom end of the range, but once you're past 3000 rpm it's no comparison. When you first step on the gas from a total stop, 0-20 is like, hmmm, Where's The Torque??? But then you get past 20mph and it just screams up past 60 and you'll like, wooooaaaaahhhh.....
Click here to see my swaps
drtweak@phoenixtuning.com
post Mar 29, 2006 - 7:19 PM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
i want one. damn cali smog.
This post has been edited by j0e_p3t: Mar 29, 2006 - 9:32 PM
post Mar 29, 2006 - 8:38 PM
Heytalktoryan
Joined Dec 13, '05
From spring texas
yeha i considered the 4agze swap but i ehard there is probalems with the transmissiona dn ti not being able to fit into the st directly...would i need a clip for this swap as well?
post Mar 30, 2006 - 12:19 AM
Jeremiah
Joined Mar 19, '06
From Rocklin, CA
QUOTE(Dr_Tweak @ Mar 29, 2006 - 8:08 AM) [snapback]415017[/snapback]
I would REALLY like to do the silvertop head on my 1.8L block, but it looks like a SEROUS pain in the ass.
post Mar 30, 2006 - 8:21 AM
Dr_Tweak
Joined Mar 31, '04
QUOTE(Jeremiah @ Mar 30, 2006 - 5:19 AM) [snapback]415451[/snapback]
Not worth it smile.gif If you're doing all that trouble, go for a 3SGTE.
Heytalktoryan, you can use the stock ST tranny, you just need a flywheel from a regular 4AGE and then it will fit. You're going to want a full engine set (engine, ecu, wiring harness, sensors and ignition) at the very least, if you're doing it yourself then I'd say yeah, get a clip.
-Doc
post Mar 30, 2006 - 9:55 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
The only thing u need to replace to fit that motor in you ST is to replace the old motor mounts on the 7A and put it all on the 4A. From there its drag, and drop.
post Apr 3, 2006 - 12:34 PM
Cutrara
Joined May 6, '05
From PA
QUOTE(Jeremiah @ Mar 28, 2006 - 8:48 PM) [snapback]414781[/snapback]
You could put the 4age head on your 7afe block and have the best of both worlds. Probably as powerful as you can get with a natrually aspired 1.8L wink.gif
I'm not sure about that, the 2ZZ-GE, a 1.8, puts out 180 HP, the "magic" 100HP/liter. But a 7A-GE is definately more powerful, but in no way is it a bolt on job. Nik is doing a 7A-GTE.
This post has been edited by Cutrara: Apr 3, 2006 - 12:35 PM
2 Pages V  < 1 2
Lo-Fi Version Time is now: December 1st, 2024 - 8:38 PM
