> passengerside motor mount, GT to ST
post Mar 22, 2006 - 11:19 PM
When drilling for the motor mount i'm slightly confused on how to get the nut inside the frame?
for the bolt to hold the mount down...
the "how-to" isn't very detailed..
post Mar 23, 2006 - 12:07 AM
post Mar 23, 2006 - 1:17 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
You arent able to get inside the frame. You need to buy the drill bit that is pictured in my how-to and drill through the frame. Buy some high strenght threaded rod, nylon lock nuts, thread locker. Make you own bolts
About 7 to 7 1/2 inches long one nut on each end of the rod.
I will return one day.
post Mar 23, 2006 - 11:52 AM
o so your putting it all the way through the frame gotcha
post Mar 23, 2006 - 1:31 PM
scothaniel
Joined May 1, '03
From Michigan
I drilled a 1" hole in the side of the frame, just large enough to get a wrench and nut in there. Just dont drop the nut, cause you'll never get it back!
Scott
West Michigan
Lo-Fi Version Time is now: February 23rd, 2025 - 4:59 PM
