> swap wiring questions, with pics, did my luck just get even worse?
post Mar 23, 2006 - 2:30 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
ok guys here are some pics and some questions
first off what is this? what does it do? and what should i do about the connections that have been torn
heres another pic of it
secondly here is a picture of my wiring harness, butt connectors.. feh.. wish i noticed them sooner.
what are all of the wires running off of that? the ones that dont go into plugs, what do i do with them?
(one is teal and is labeled fan relay, one is green/yellow and labeled ac switch, one is brown and labeled stop lamp (i think thats in that area, ill go check again in a second)
more pics of harness
thanks guys, i hope i dont have bad new coming, i think as lagos said i might set my car on fire and walk away frown.gif
post Mar 23, 2006 - 2:35 PM
Chanh55
Joined Jun 29, '03
First pic is the ignitor or something to do with the ignition. You can't start your car without it... pretty important.
post Mar 23, 2006 - 2:37 PM
Vacchus
Joined Mar 9, '06
From Crete - Greece
I think you have a big problem dude..
Seems like your wiring has turned to a spagetti..
post Mar 23, 2006 - 2:45 PM
the 1st pic is you resistor pack for your injectors.
that wiring is really poorly done, and you will have nothing but problems with those crimps. you can even tell that one of them came loose already on the reisitor pack.
i wuld take those crips and blue spicers out and solder and heat shrink everything.
laugh.gif you know thats not what i said...lol
This post has been edited by lagos: Mar 23, 2006 - 2:46 PM
post Mar 23, 2006 - 2:59 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
now more than ever i want to just roll it all off a cliff
post Mar 23, 2006 - 3:17 PM
QUOTE(brianforster @ Mar 23, 2006 - 2:59 PM) [snapback]411969[/snapback]
all a normal part of the swap. get those thoughts out of your head and keep setting small goals for yourself that you can finish.
post Mar 23, 2006 - 3:26 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
well everone has convinced me to do it the right way since apparently this engines previous two owners and the people they had work on the harness didnt.. im going to solder/heat shrink the connections, and hopefully in the process fix wires that lead to nowhere
post Mar 23, 2006 - 6:02 PM
Rjb23
Joined Feb 8, '04
From KY
I hate to tell you this but there is no way you will have that car running by sunday. Also its better to wait to put you engine in and hook the harness up to the engine before you put it in.
You need to bust out the wiring diagram and see where those wires are supposed to go to if you are gonna do your own harness. From the looks of it I would doubt if all those wires are going to the right places.
post Mar 23, 2006 - 9:19 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
which colors from the injectors match up to which colors on the resistor pack?
on my resistor pack i have : black black white black black
on my injectors i have redblue, yellow, black, red, and blue
post Mar 24, 2006 - 7:54 AM
HAHAHAHAH THATS MY LINE!!!!
hehehe good stuff.
man that harness looks HACKED.
looks like its gonna take some WORK to get that thing up and running.
post Mar 24, 2006 - 8:31 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Oh boy.
Okay, #1, if you're going to be soldering be sure you're doing it right, you need a good iron, flux paste, and the right kind of solder. Otherwise your connections will be crappy and give you more trouble (I've repaired many harnesses with "soldered" connections that were just scarey).
Resistor pack, there's one wire that carries power TO it, and four wires that carry power back. The one wire that has power going to it is the larger of the four on the harness (normally they are black with an orange stripe) and that wire goes to the one on the resistor pack that is a different color than the rest. I think the white one (and the rest are black). The order of the other four doesn't matter.
The fan relay wire wasn't hooked up, that's pretty common for people to do. Your fan will run all the time with that configuration. (That wire comes from the fusebox plug, right?) Or, buy a fan temp switch from an ST and install that on your 3SGTE, and hook that wire up.
The other two wires don't worry about, at least for now.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Mar 24, 2006 - 9:52 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
THANK YOU THANK YOU THANK YOU tweak.
chucky did most of the soldering and he does it pretty much for a living so i trust him.
and you mean there will be air always coming out of the vents? will i still be able to control fan speed?
what is this fan temp switch from an st? shouldnt i have that already on my st?
post Mar 24, 2006 - 9:53 AM
he means the radiator fan....
post Mar 24, 2006 - 9:57 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
post Mar 24, 2006 - 10:19 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
originally, it looks as if the solid black wire coming from the fuel injectors was used on the white spot in the resistor pack. but i have traced the wires and red/blue/black/yellow all go to individual injectors, leaving me to believe that the red and blue wire is the power wire.
it seems to have been wired incorrectly before though, with a million butt splics and wire taps, this harness was surely hacked up a bit, but i have removed every piece of plastic on this baby and soldered it/heatshrinked it!
*crosses fingers*
post Mar 24, 2006 - 12:20 PM
QUOTE(brianforster @ Mar 24, 2006 - 10:19 AM) [snapback]412479[/snapback]
*crosses fingers*
umm we covered this over AIM, remember? wite wire is power, so connect it to the white wire on the pack. then connect the black wires together, the order dosnt matter.
Lo-Fi Version Time is now: February 24th, 2025 - 4:26 AM
