4 Pages V  < 1 2 3 4 >
> DYNO RESULTS, reached 1.4 bar boost
post Mar 27, 2006 - 8:13 AM
tufy
Joined Dec 3, '03
From Cyprus
we just finished mapping. we reached 1.4 bar boost after installing new greedy type R bow, 255 lph apexi fuel pump and 5 bar map sensor. i think now we are so close to 500 whp now or more. i am waiting for new injectors and fuel rail to go dyno one more time.
post Mar 27, 2006 - 8:57 AM
very nice tuffy!
what rail are you planning to use?
post Mar 27, 2006 - 2:15 PM
snakeloa
Joined Sep 15, '03
From Germany
Where did you get the map sensor from tufy? What is this sensor doing exactly?
This post has been edited by snakeloa: Mar 27, 2006 - 2:16 PM
Spec to be found on my website....
post Mar 27, 2006 - 2:48 PM
a MAP sensor reads the pressure and converts it into OHMS...
tells the computer how much boost/vacuum is being made
post Mar 27, 2006 - 5:58 PM
snakeloa
Joined Sep 15, '03
From Germany
and what does the "5 bar" indicate. that you can go up to 5 bar? The usual OEM Sensor how much bar can this one handle?
Is this a must?
@tufy Where did you buy it?
cheers Joerg
This post has been edited by snakeloa: Mar 27, 2006 - 6:18 PM
post Mar 27, 2006 - 7:02 PM
"The Manifold Absolute Pressure (MAP) sensor measures the changes in the intake manifold pressure which result from engine load (intake manifold vacuum) and rpm changes; and converts these into a voltage output. By monitoring the sensor output voltage, the ECU know the manifold pressure. At lower pressure output voltage will be about 1 to 2 volts at idle. While at higher pressure or at Wide Open Throttle (WOT) output voltage will be about 4 to 4.8. The MAP sensor is also used, under certain conditions, to measure barometric pressure, allowing the ECU to make adjustments for different altitudes. The ECU uses the MAP sensor to control fuel delivery and ignition timing."
2 bar = 14.7 psi (oem i think)
3 bar = 29.4 psi
4 bar = 44.1 psi
5 bar = 58.8 psi
post Mar 28, 2006 - 12:54 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
QUOTE(playr158 @ Mar 27, 2006 - 5:02 PM) [snapback]414091[/snapback]
3 bar = 29.4 psi
4 bar = 44.1 psi
5 bar = 58.8 psi
Ehm ehm...... Dan:
1 bar = 14.5037738 pounds per square inch
3 bar = 29.4 psi
4 bar = 44.1 psi
5 bar = 58.8 psi
<<<<<< DCw / JDMart >>>>>>>
post Mar 28, 2006 - 1:01 AM
3 bar is now 29psi
4 bar 43.5psi
5 bar 58psi
i got the orignal #s off a quick yahoo scan
"1 Bar MAP sensors are used on NA(naturally asperated) vehicles.
2 Bar MAP Sensors are used on forced induction vehicles(Turbo & Supercharged). They can measure up to 2x the apmospheric pressure(29.4psi), so that means it can measure up to 14.7psi boost(the atmosphere is 14.7psi + 14.7psi from the turbo/supercharger).
3 Bar MAP sensors can measure up to 44.1psi, which translates to 29.7psi boost from a Turbo/supercharger."
http://www.rmsirace.com/emanage/GM_MAP_sen...tification.html
This post has been edited by playr158: Mar 28, 2006 - 1:06 AM
post Mar 28, 2006 - 1:06 AM
doGGy
Joined Oct 28, '02
post Mar 28, 2006 - 1:23 AM
tufy
Joined Dec 3, '03
From Cyprus
QUOTE(playr158 @ Mar 27, 2006 - 1:57 PM) [snapback]413809[/snapback]
very nice tuffy!
QUOTE(snakeloa @ Mar 27, 2006 - 7:15 PM) [snapback]413947[/snapback]
i am planning to use HKS fuel rail. but still i dont have prices to decide.
my tunner installed this map sensor. thanks doogy and playr 158 for info.
btw. i drived my car yesterday night. it was awsome. power is at little bit high rpms but once turbo spoools its very fast. its hard to drive. i have to made some more practice to improve my driving skills.
This post has been edited by tufy: Mar 28, 2006 - 3:47 AM
post Mar 28, 2006 - 1:39 AM
urbandork
Joined Jul 16, '04
From Los Angeles
wow i want one
post Mar 28, 2006 - 3:18 AM
snakeloa
Joined Sep 15, '03
From Germany
@playr158 Thank you for your explanation
Ok then i willl have to get one as well. Where can i get such a 5 Bar Map Sensor?
@tufy what ECU are you running? Power FC?
post Mar 28, 2006 - 3:35 AM
tufy
Joined Dec 3, '03
From Cyprus
QUOTE(snakeloa @ Mar 28, 2006 - 8:18 AM) [snapback]414451[/snapback]
yes i have power fc. ecu.
i just checked my old sensor. it writes ''sensor assy. turbo pressure'' brand is denso. 5 bar map sensor is also denso.
post Mar 28, 2006 - 5:47 AM
snakeloa
Joined Sep 15, '03
From Germany
Thank you tufy!
Tell me do you use the datalogit or what did your tuner use to get the maps set right.
cheers Joerg
post Mar 28, 2006 - 1:28 PM
recycle
Joined Jul 12, '03
From centre of universe, nicosia, cyprus
QUOTE(playr158 @ Mar 28, 2006 - 8:01 AM) [snapback]414408[/snapback]
3 bar is now 29psi
4 bar 43.5psi
5 bar 58psi
this is so wrong
2 bar is 29psi
4 bar is 58psi
IPB ImageIPB ImageIPB ImageIPB ImageIPB ImageIPB Image
post Mar 28, 2006 - 1:46 PM
afroman
Joined Feb 9, '03
From Sioux falls, South Dakota
i think what he is tring to say is that a 3 bar map sensor can read 29 psi of boost ans so on.
-Aaron-
post Mar 28, 2006 - 2:25 PM
QUOTE(recycle @ Mar 28, 2006 - 1:28 PM) [snapback]414625[/snapback]
3 bar is now 29psi
4 bar 43.5psi
5 bar 58psi
this is so wrong
2 bar is 29psi
4 bar is 58psi
actually we are both right...your talking atmospheric pressure....mine is in turbo/supercharger boost pressure
"2 bar map = They can measure up to 2x the atmospheric pressure(29.4psi), so that means it can measure up to 14.7psi boost(the atmosphere is 14.7psi + 14.7psi from the turbo/supercharger)."
you have to remember turbo pressure is ABOVE atmosphere...so 0 boost = 14.7 atmosphere so when you read 14.7 on your gauge thats really 29psi...
make sense now?
This post has been edited by playr158: Mar 28, 2006 - 2:29 PM
post Mar 29, 2006 - 12:45 AM
tufy
Joined Dec 3, '03
From Cyprus
QUOTE(snakeloa @ Mar 28, 2006 - 10:47 AM) [snapback]414471[/snapback]
Thank you tufy!
cheers Joerg
he used his laptop to tune my car as seen in photos...
post Mar 29, 2006 - 8:11 AM
snakeloa
Joined Sep 15, '03
From Germany
That is for sure wink.gif But which program did he run on it "Datalogit" the "Excel" or any other Software?
post Mar 29, 2006 - 8:46 AM
tufy
Joined Dec 3, '03
From Cyprus
QUOTE(snakeloa @ Mar 29, 2006 - 1:11 PM) [snapback]415019[/snapback]
ohh. he was using datalogit.
Lo-Fi Version Time is now: November 27th, 2024 - 8:17 PM
