> need a new trans, what manuals will fit 5sfe?
post Mar 24, 2006 - 6:41 PM
b1gr3d
Joined Feb 25, '03
From Springfield, MO
well noticed a day before i went on vacation that the clica was making a strange noise when it increased in speed. took it to the transmission place and it turns out that something in the diff is messed up and it will be cheaper to replace it than to rebuild........NOOOOOO!!!!
my question is this : what other transmissions will fit this engine?
this has probably been posted before but I couldn't find it. it should be asticky if it isnt already
Coming in 2010
post Mar 25, 2006 - 6:51 AM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
*edit* Dont take this post and a solution rather a direction in which to start your research.
1. 5sfe-S54 tranny?
2. 3sge-S5X tranny?
3. 3sgte-E153 tranny from mr2
4. Solara V6 5spd tranny
#s 3 & 4 require custom motor mounts and axles.
#2 some come with an LSD not sure which ones those were though (redtop Beams tranny?)
This post has been edited by celicast3sgte: Mar 25, 2006 - 6:53 AM
post Mar 26, 2006 - 9:53 AM
b1gr3d
Joined Feb 25, '03
will a 2001 mr2 trans work/?
Coming in 2010
post Mar 26, 2006 - 10:03 AM
Kadett
Joined Mar 17, '05
From The Netherlands
No since it has the 1zz-ge engine in it not the 7a-fe.
post Mar 26, 2006 - 11:34 PM
scothaniel
Joined May 1, '03
From Michigan
Actually, the newer Celica's are using a newer version of the same C series trans as the 7A's and 4A used. I'm pretty sure they'll bolt right up, but check with monkeywrenchracing.com to verify.
Scott
West Michigan
post Mar 27, 2006 - 1:32 PM
b1gr3d
Joined Feb 25, '03
how does 300 sound for a 94 5 spd with 35k on it???
This post has been edited by b1gr3d: Mar 27, 2006 - 1:33 PM
Coming in 2010
post Mar 28, 2006 - 12:38 AM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
sounds very good
Lo-Fi Version Time is now: December 3rd, 2024 - 3:19 PM
