Chop the top? |
Chop the top? |
Mar 27, 2006 - 9:17 PM |
Moderator Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
I'd like to see this happen, just think about this. All four pieces of new glass alone are going to cost more than your car is worth. You can say you'll "just get plastic". Good luck getting a shop to pass a car with a plastic windsheild, or any of the other windows.
Two ways you have to think about this: One. Spend a ton of money and get that inspection legit. Two. Throw in the plastics and hope to god a cop doesnt tap your window. Good luck Dan -------------------- I will return one day. |
Mar 27, 2006 - 9:18 PM |
Enthusiast Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
CHOP CHOP!
-------------------- Kawi Love |
Mar 27, 2006 - 9:27 PM |
Enthusiast Joined Feb 25, '03 From Springfield, MO Currently Offline Reputation: 1 (100%) |
i would cut a frame around the windshield and lean it back. much cheaper. for the back i would cut the hatch bellow the glass and lean it in as well...dunno how it would look but it's a just an easy solution to the glass problem
-------------------- Coming in 2010 full paintjob - new wheels - modified body - new interior - engine build- marriage |
Mar 27, 2006 - 9:28 PM |
they actually lean and cut the glass to fit i believe....
Mar 27, 2006 - 9:40 PM |
for shiznits and giggles here is a general how-to
http://www.rodandcustommagazine.com/techarticles/0304_chop/ btw i'm not doing this my pockets arn't deep enough BUT TAKING DONATIONS |
Mar 27, 2006 - 9:50 PM |
QUOTE(playr158 @ Mar 27, 2006 - 8:40 PM) [snapback]414227[/snapback] for shiznits and giggles here is a general how-to http://www.rodandcustommagazine.com/techarticles/0304_chop/ btw i'm not doing this my pockets arn't deep enough BUT TAKING DONATIONS the parts around the back glass is egggggzactly what i meant DO IT!!!!! if you have a welder and some cutting tools you can do anything, oh and alot of elbow grease/want to do it This post has been edited by b1gr3d: Mar 27, 2006 - 9:53 PM -------------------- Coming in 2010 full paintjob - new wheels - modified body - new interior - engine build- marriage |
Mar 27, 2006 - 10:36 PM |
Enthusiast Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
Sounds easy, should take 20, 25 minutes tops.
Mar 27, 2006 - 10:46 PM |
Enthusiast Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
haha, id consider it a job well done if i got to the point of needing glass on a project like this
Mar 27, 2006 - 10:59 PM |
Enthusiast Joined Jan 6, '06 From Tennessee Currently Offline Reputation: 0 (0%) |
Maybe I'm wrong, but it seems like regardless of you you do it, you're gonna have to get some custom glass done, because if you section the roof and lean the hatch and windshield, you've still changed the geometry of your side windows, and if you cut and lower the whole roof, you've changed the geometry of the whole thing. But it would definitely be one of the most unique celis on the road. If you've got the $$$$ and you don't mind spending it, I'd say go for it. You'd have a show winner for sure when you're done.
Mar 27, 2006 - 11:06 PM |
you section the roof into 4 pieces really...
when you go down you also make it wider..thus keeping the sides at the same "geometery" but take some height away.. the front and rear get cut down and reangled...all stock glass can get reused i do believe aka leave this up to a hot rod shop thats done it a few hundred times |
Mar 27, 2006 - 11:14 PM |
Enthusiast Joined Jan 16, '06 From Lima, ohio Currently Offline Reputation: 0 (0%) |
QUOTE(ZacMan1987 @ Mar 27, 2006 - 10:59 PM) [snapback]414287[/snapback] Maybe I'm wrong, but it seems like regardless of you you do it, you're gonna have to get some custom glass done, because if you section the roof and lean the hatch and windshield, you've still changed the geometry of your side windows, and if you cut and lower the whole roof, you've changed the geometry of the whole thing. But it would definitely be one of the most unique celis on the road. If you've got the $$$$ and you don't mind spending it, I'd say go for it. You'd have a show winner for sure when you're done. if you are going through all this work, go lexan forget glass, besides the front winshield give me a pair of scisors, some white school glue, newspaper, and tape and i could do it |
Mar 27, 2006 - 11:16 PM |
Enthusiast Joined Oct 12, '05 From Texas Currently Offline Reputation: 59 (100%) |
If anyone does this...i hope they do it right, and have custom glass etc...not plastic
~snap -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Current: 850rwhp C6 Corvette Grandsport, Gen1 6.2L Ford Raptor |
Mar 27, 2006 - 11:19 PM |
Enthusiast Joined Jun 19, '05 From New York Currently Offline Reputation: 1 (100%) |
idk if it would look that good though, i mean it looks amazing from the side but idk from the front, are cars arent that wide, and i think this would jus make it look wayy to long
Mar 27, 2006 - 11:20 PM |
widebody fixes that
i mean if you got the money why not go balls out right |
Mar 27, 2006 - 11:21 PM |
Enthusiast Joined Mar 3, '05 From Hollywood, FL Currently Offline Reputation: 0 (0%) |
not do able, you would have to change the entire top of the car, this mod would run you well into the $10k for all the time and effort and custom glass. If anyone even attempts, mad props.
-------------------- To live, is to suffer
To survive, thats to find meaning, in the suffering.... |
Mar 27, 2006 - 11:27 PM |
here is the front nick
lowered and widen'd ^^^ stock vvv and it is doable don't talk out your ass none of us have a clue about how much it would cost...your just making your self look like a fool This post has been edited by playr158: Mar 27, 2006 - 11:27 PM |
Mar 27, 2006 - 11:31 PM |
common sense would tell you all you need to know, sure you can dream, its just gonna end up like the suprica. If you cant work with fiberglass, what makes you think cutting, bending, and welding metal will be easier? Good luck getting your celica out of photoshop.
Mar 27, 2006 - 11:32 PM |
Enthusiast Joined Aug 16, '04 From Baton Rouge, LA Currently Offline Reputation: 0 (0%) |
Well guys I might be picking up a black 6th gen that has been sitting in a parking lot for the past 8 months and hasnt moved for a project. And if i do i might consider doing this. I worked at a glass company this past summer and they could easily make the glass for me for free.
Mar 27, 2006 - 11:38 PM |
who said i was doing this? i never did....
and really honestly look out into the car world roof chops are a COMMONALITY in the hot rodding industry...so wats the difference? there isn't one...a roof is a roof and windshield is a windshield wat can be done on a ford coupe can be done a 6th gen celica... glass DOES NOT in all cases have to be custom made..in cases it is possible to use the existing stock glass and cut to fit..yes this does happen and glass is cuttable... BTW: http://www.ifcustom.com/web%20pages/services/choptops.htm they use stock glass in lots of applications projects start at 3500$ |
Mar 28, 2006 - 12:02 AM |
Enthusiast Joined Mar 19, '06 From K3, IL Currently Offline Reputation: 0 (0%) |
I am seriously debating taking out a loan for this instead of a clip with a 3sgte
Lo-Fi Version | Time is now: November 23rd, 2024 - 5:46 AM |
