![]() Enthusiast ![]() ![]() ![]() Joined Jul 5, '05 From Arlington, TX Currently Offline Reputation: 2 (100%) ![]() |
i just bought the celica a gift. Just like the title says - its the Cusco PILLOW BALL UPPER MOUNT SET/ FRONT/ CAMBER ADJUSTABLE -- from www.japanparts.com
total came out to be $249.33. - i think it'll be 2-3 wks before i receive it since its coming from Japan. Can't wait - this should do wonders to the Tein setup that I already have - didn't order the rear ones since i'm on a budget this month- One step closer to making this car a better ride. I definitely will have pictures when I install it. ![]() ![]() ![]() ![]() ![]() This post has been edited by celicarus: Apr 8, 2006 - 9:47 AM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 25, '05 From Sydney, Australia Currently Offline Reputation: 0 (0%) ![]() |
Nice
![]() Cant wait to hear the reviews. I'm aiming for the same setup as well. -------------------- ![]() 98 ST204 ZR - Black Beauty - Roaming the streets of Sydney 73 TA22 LT - Tiffany Blue - Mint Classic Weekend Cruiser 75 TA22 LT - Snow White - Mint Classic Weekend Cruiser 77 RA28 LT - Flubber Green - Mint Classic Weekend Cruiser 94 MX-5 NA8 Clubman - Red Racer - Looking for corners WIP Project: 69 RT40 Corona, 2nd WIP Project: 66 RT40 1600s Corona 86 Corona RT142 - Daily Driver 6GC 4 Life Baby!!! |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) ![]() |
is this just to angle the tires outward for racing or what? seems like allot of bread for some adjustable mounts.
i don't know if its my eyes playing tricks on me or what - but after lowering the car with the teins - the tires/rim has a slight slant to it like this \ --- hope the cusco will help with that
my mounts were messed up anyways so i needed new ones - i think before i had the teins the dropzone coilovers wore out the mounts real bad - |
gotcha, they look really sweet. post many pics with them on
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 15, '05 From Toronto Currently Offline Reputation: 4 (100%) ![]() |
when u say you have some negative camber..like \ <--- that...is it in the rear?? cuz i have that same problem.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) ![]() |
My Tein SS kit wil come with the pillowball uppermount included.
-------------------- JDM Powerplant installed, BPU coming very soon!
![]() Enthusiast ![]() ![]() ![]() Joined Dec 3, '03 From Cyprus Currently Offline Reputation: 0 (0%) ![]() |
cusco is perfect. i have same on my car. i should say that thay are a little bit uncomfortable but improves handling.
TIEN does not come with upper pillow mounts on their SS kit....
QUOTE(playr158 @ Mar 28, 2006 - 7:04 PM) [snapback]414587[/snapback] TIEN does not come with upper pillow mounts on their SS kit.... They do for the ST202. Sorry had to mention that. CELICA (Mcpherson Strut) ST202 FWD 2000 EDK01-12140 ¥39,500 ¥41,475(incl TAX) Ft:P/U <-------- Pillowball Uppermount!!! Rr:R/U GST86-B1SS4 ¥133,000 ¥139,650(incl TAX) I.D.70 4.0k/300mm I.D.70 3.0k/250mm Ft:NO Rr:NO Ft:-50mm Rr:-45mm Ft:-70to-24mm Rr:-65to-12mm *Upon EDFC installation; Ft - Need to take precaution when adjusting the camber angle as some interference with the motor might be caused.Bonnet insulator needs to be cut or removed. Rr - Interior needs to be cut. -------------------- JDM Powerplant installed, BPU coming very soon!
lucky
QUOTE(playr158 @ Mar 28, 2006 - 7:58 PM) [snapback]414609[/snapback] lucky Thats called being blessed ![]() ![]() -------------------- JDM Powerplant installed, BPU coming very soon!
QUOTE(Valo666 @ Mar 27, 2006 - 11:52 PM) [snapback]414397[/snapback] when u say you have some negative camber..like \ <--- that...is it in the rear?? cuz i have that same problem. its more noticeable in the rear than the front -- i will be ordering the rear also some time in april |
Enthusiast ![]() ![]() Joined Dec 21, '05 From dallas Currently Offline Reputation: 3 (100%) ![]() |
why does someone need these? i thought these are good for people that do drifting because they want that angle in the front. My friend had these on his 240, they creeked real bad when he turned. Couldnt someone just get camber correction bolts to fix the negative camber a drop gave?
the rear is fixed and NON adjustable...
QUOTE(playr158 @ Mar 28, 2006 - 2:58 PM) [snapback]414688[/snapback] the rear is fixed and NON adjustable... so i should just stick with oem mounts for the rear? - though i still need to replace them since its pretty worn - |
received the mounts this morning - i was limited on time and did not have time to take any pictures - cause i knew i would be late for work --
ride quality definitely was better than stock mounts - to those who plan on getting Teins SS and using cusco mounts - you will not be able to use EDFC - so don't bother buying it -- cause with the cusco mounts - their will not be enough space to squeeze it in - not an issue with hood clearance - just an issue with no more thread showing from the top bolt another issue is that the cusco mount raises the coilovers about 1 inch - so you will have to lower it again - if i remember correctly their are 16 or 20 grooves on the body of the strut for lowering/higher adjustments - -- before i had 8 grooves going from bottom to top - now i have to lower it a bit more (not sure if that made any sense - but when i come back from my trip to MO next week - i'll remove the wheels n take pictures for everyone to see) -- another thing i noticed that wasn't there before with stock mounts - is a new noise - now i can hear the strut/coilover gas pressure when going over bumps -- not sure if this is normal or not - but it doesn't bother me since ride quality is better -- -- now i'm gonna head out to get a realignment done -- |
might be the settling in stage, if it continues after a week, let us know.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) ![]() |
i hear it too so dont worry.
i got the alignment done - and steering wheel centered --
one bad thing about the cusco mounts - is that it doesn't have a bearing device - because without that its compressing the parts or springs part causing a little grinding noise -- when the time allows i will have to contact a bearing manufacturing company to produce something for this problem -- the noise wasn't as bad as the dropzone coilovers i had back then -- cornering feels a bit better -- |
Lo-Fi Version | Time is now: February 13th, 2025 - 3:11 PM |
