3 Pages V  < 1 2 3 >
> Cusco PILLOW BALL UPPER MOUNT SET, updated with Pics Page 1
post Apr 6, 2006 - 11:27 PM
http://www.evilspeed.com/
for bearings
post Apr 8, 2006 - 9:50 AM
celicarus
Joined Jul 5, '05
From Arlington, TX
pics on page 1
post Apr 10, 2006 - 2:52 PM
celicarus
Joined Jul 5, '05
From Arlington, TX
came back from my trip - driving conditions were ok - except that i should of changed the settings on the Teins - cause the ride was a little stiff -
on the way back - the mounts started to make clunking sounds - in the 3rd and 4th picture the top middle nut came loose - probably due to ride being to stiff and bumpy -- so after tightening it back up - noise went away
-- i will have to call john from evilspeed.com and pickup some bearings for the spring - though it wasn't a problem with oem mounts
post Apr 10, 2006 - 7:56 PM
post Apr 11, 2006 - 1:45 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
How long did it take to get them installed? I want!
**** Photobucket
post Apr 11, 2006 - 2:23 PM
celicarus
Joined Jul 5, '05
From Arlington, TX
1 hr-- first side took about 40 minutes the other side was about 20 minutes ---
post Aug 13, 2006 - 11:59 PM
Jaws4God
Joined Mar 27, '04
what kind of adjustment does that allow? I know i'm at like -3 and -4 on the fronts.. would they adjust that much??
Thanks!
post Aug 14, 2006 - 1:33 AM
yes, i'm pretty sure they allow for more then that
post Aug 14, 2006 - 8:14 PM
Jaws4God
Joined Mar 27, '04
QUOTE(playr158 @ Aug 14, 2006 - 6:33 AM) [snapback]468751[/snapback]
where can you buy them? I went to the JapanParts site and didn't see them listed on there..
Thanks!
This post has been edited by Jaws4God: Aug 14, 2006 - 8:15 PM
post Aug 14, 2006 - 11:58 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(Jaws4God @ Aug 14, 2006 - 8:14 PM) [snapback]469044[/snapback]
Thanks!
Speed Source - click here
post Aug 15, 2006 - 1:46 AM
QUOTE(Jaws4God @ Aug 14, 2006 - 9:14 PM) [snapback]469044[/snapback]
Thanks!
just gotta look in the right place daniel son
http://www.japanparts.com/db/partslist.php...&maker=&volkey=
post Aug 15, 2006 - 12:11 PM
Jaws4God
Joined Mar 27, '04
QUOTE(playr158 @ Aug 15, 2006 - 6:46 AM) [snapback]469148[/snapback]
Thanks!
Cool thank you.. Idk how I didn't find it.. all I kept seeing was the strut bars..
post Aug 15, 2006 - 3:18 PM
jdg371
Joined Jun 14, '05
Hmm suspension mods! Can they be used with uhh GCs and Konis?
post Aug 15, 2006 - 3:23 PM
yes
they can be used with any 6th gen celica suspension
post Sep 17, 2006 - 5:53 PM
Jaws4God
Joined Mar 27, '04
so what did you all decide with the bearing? does it only matter if you have springs? I am just wondering if I need to get something like that too...
I ordered them so they should be on the way.. just realized that one of my tires is bald on the front now and that scares me... :-(
post Sep 25, 2006 - 11:28 AM
Jaws4God
Joined Mar 27, '04
Looks like mine came in today according to DHL.. we'll see when I get home...
post Sep 25, 2006 - 12:10 PM
nice, oh and just pick up some bearing grease and grease the top of the spring before you install it (be generous) that will preven the binding!
good luck
post Sep 25, 2006 - 2:04 PM
boosted_K2
Joined Aug 30, '02
From Michigan
did you attempt to get the car realigned after installing the new suspension? chances are the pillowball mounts were not needed to achieve the type of alignment you would want. Usually pillowball mounts are best used for quick onsite adjustments and are not necessarily needed to achive a proper alignment.
No but I don't buy it
Cause I'm...
post Sep 25, 2006 - 2:08 PM
boosted_K2
Joined Aug 30, '02
From Michigan
QUOTE(celicarus @ Mar 28, 2006 - 5:20 PM) [snapback]414693[/snapback]
QUOTE(playr158 @ Mar 28, 2006 - 2:58 PM) [snapback]414688[/snapback]
the rear is fixed and NON adjustable...
so i should just stick with oem mounts for the rear? - though i still need to replace them since its pretty worn -
just because they are "fixed and NON adjustable" doesnt mean they cant be set, you can use the play in the bolts between the knuckle and damper to "adjust" the camber. my MR2 has the same fixed rear layout and when i reinstalled my driverside rear suspension i maxed the camber out to ~4 degrees negative camber... the other side was set to 1.5. whenever you loosen/remove these bolts you should get the alignment fixed.
Cause I'm...
post Sep 25, 2006 - 7:50 PM
Jaws4God
Joined Mar 27, '04
yeah, i don't plan to use it for quick adjustment.. I just need to get them aligned since my airbags have it off by like -4 degrees. i just hope these will allow for that much adjustment..
3 Pages V  < 1 2 3 >
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: February 13th, 2025 - 6:14 PM
