got a very STRANGE question |
Mar 28, 2006 - 11:12 AM |
Enthusiast Joined Apr 8, '03 From New York City Currently Offline Reputation: 0 (0%) |
ok I know this is gonna be really messed up.. but I got a question..
I've owned my 6gc for like 7 years now and all of a sudden I am not sure if my headlight stake is working. so my question is: when the headlight is OFF when you pull on the stake you flash high beam.. but what is supposed to happen when you PUSH the stake in??? is it supposed to do NOTHING or does it turn on HIGHBEAM??? I could not find the answer in the manual!! I could've sworn that should turn on highbeam and now it's broke. yes after owning this car for 7 years I don't remember how the headlight is supposed to operate! |
Mar 28, 2006 - 11:28 AM |
Enthusiast Joined Jun 29, '03 Currently Offline Reputation: 0 (0%) |
If you pull it flashes the High Beam till you release.
If you push it turns on the High Beam till you pull it back. |
Mar 28, 2006 - 11:30 AM |
Enthusiast Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
im pretty sure that if the headlights are off pushing the stick forward or pulling it back will do nothing either way
Mar 28, 2006 - 11:59 AM |
so Im not the only guy who is not sure how the headlight stick is supposed to work.. I'm sure pulling it while it's off would turn on the high beam because you do that to "flash to pass".. but the question is what if you push it forth does it turn on the high beam and make it stay on??
Mar 28, 2006 - 12:13 PM |
Out of curiosity, why is this important?
If you want your high beams on, just turn them on. If you don't want your high beams on, leave them off. As I see it, it doesn't matter what happens when the lights are off and the high beam switch is on. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Mar 28, 2006 - 12:40 PM |
Enthusiast Joined Jun 30, '05 From Chattanooga, TN Currently Offline Reputation: 5 (100%) |
pushing it forward wont do anything with the lights off, if the lights are on then pushing it forward will turn your brights on
Mar 28, 2006 - 6:01 PM |
Enthusiast Joined Feb 8, '05 From Cambridge, ON, Canada Currently Offline Reputation: 1 (100%) |
yep just tried this yesterday
if the lights aren't turned on, pulling the high beam stick won't do anything only if your lights are on will it flash -------------------- lissa | 1997 Celica Convertible
*My other ride is your boyfriend* ;) |
Mar 28, 2006 - 6:03 PM |
QUOTE(lil_lissa @ Mar 28, 2006 - 11:01 PM) [snapback]414730[/snapback] yep just tried this yesterday if the lights aren't turned on, pulling the high beam stick won't do anything only if your lights are on will it flash woo i was right |
Mar 28, 2006 - 11:17 PM |
Enthusiast Joined Oct 5, '03 From South TX. Currently Offline Reputation: 14 (100%) |
both my celicas flash all 4 lights even when they are off, and when the car is turned off as well///
QUOTE(lil_lissa @ Mar 28, 2006 - 4:01 PM) [snapback]414730[/snapback] yep just tried this yesterday if the lights aren't turned on, pulling the high beam stick won't do anything only if your lights are on will it flash oh no your light stick is broken!! or maybe it's because yours a 97 while mine is a 98?? I can certainly flash to pass without having to switch on the headlights first. in any case the real point of my original post is not so much whether the light stick is supposed to work but rather after driving the car for so many years and through so many miles we (as evident by these posts) still cannot say with certainity how one of the most important controls in our car is supposed to operate.. at least not without checking.. and I thought I was the only one!! |
Mar 31, 2006 - 9:51 PM |
^^^ i HAVE checked! lol mine doesn't do anything if they aren't on... i have my lights on whenever i'm driving the car though because we're supposed to have daytime running lights anyways, so mine are always turned on no matter what. but just the other day in my driveway i tested it out, and it didn't do anything unless they were turned on!
Apr 16, 2006 - 3:40 AM |
for me if everythings off and i pull to flash all four lights come on but if i push to stay on nothing happens
[im sure of that] -------------------- |
Apr 16, 2006 - 5:57 AM |
Enthusiast Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
for most Toyotas:
While low beams are OFF: Push stick forward (stick will stay in that position, but high beam won't come on) Pull stick backward (stick will not stay in that position, you'll have to hold on to the stick, though there will be high beams) -------------------- |
Lo-Fi Version | Time is now: December 11th, 2024 - 7:51 AM |
