> 4agze Whats The Real Deal with this swap?
post Mar 28, 2006 - 1:26 PM
Drew-887
Joined Jan 5, '05
From Upper Darby, PA(5 min away from Philly)
Ive been reading alot about different swaps mainly the 4agze and the 20 valve silvertop. I made a plan do a slivertop swap but ive always wanted a GZE. I just wanted to ask you all some questions to see if they were true.
1. Does the GZE top mount intercooler fit under our hoods?
2. Is is true that the GZE only runs on 92 octane and higher or could you put in mid grade gas and be safe?
3. Do you need to buy a oil cooler and upgraded radiator?
4. Can the Slivertop 20 valve compete with the GZE?
Heres where I got my info
http://www.club4ag.com/faq%20and%20tech_pa...0considered.htm
post Mar 28, 2006 - 3:55 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
1. Probably, but it would be a very bad idea to leave it there since it would get no airflow.
2. You might be okay, but you should be running the best octane you can get.
3. No.
4. Kind of.... no, actually, not really. The blacktop can though, it's a little faster.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
Lo-Fi Version Time is now: February 22nd, 2025 - 12:19 PM
