3 Pages V  < 1 2 3 >
> clunking rear?, check this out
post Apr 3, 2006 - 8:40 PM
HaRv3sTeR
Joined Nov 22, '03
From Tracadie-Sheila, NB (Canada)
QUOTE(bufferdan @ Apr 3, 2006 - 3:27 PM) [snapback]417195[/snapback]
Advance Auto Parts had to order them for me
TRW Sway Bar Mount Bushing
Part Number: HB1180
Price: $4.68 each
I replaced mines last summer but it didnt help...guess ill change control arm next time
This post has been edited by HaRv3sTeR: Apr 3, 2006 - 8:40 PM
post Apr 3, 2006 - 8:52 PM
Celicas_Secret
Joined Jan 6, '06
From North Grosvenordale, CT
post Apr 25, 2006 - 10:15 AM
azian_advanced
Joined Apr 18, '05
From Calgary
This post has been edited by azian_advanced: Feb 12, 2007 - 1:46 AM
post Apr 26, 2006 - 10:54 AM
HaRv3sTeR
Joined Nov 22, '03
QUOTE(azian_advanced @ Apr 25, 2006 - 3:15 PM) [snapback]426204[/snapback]
weird that the interior control arm (#487x0A) doesnt look the same as this one (#2) on this picture:
do you think Rayme that I should change both interior and exterior arms?
This post has been edited by HaRv3sTeR: Apr 26, 2006 - 10:55 AM
post Apr 26, 2006 - 1:38 PM
Rayme
Joined Feb 18, '06
From NB, Canada
from the reference picture azian posted it seems you can change the bushing in the front arms, but you need whole arms in the rear arms...the part number is specified for the celica without the sport package.
in the 5th gen you need both new arms..this is wierd
This post has been edited by Rayme: Apr 26, 2006 - 1:44 PM
-Rémy
02 SiR, 08 250R
post Apr 26, 2006 - 3:30 PM
Starcraftjunkie
Joined Nov 21, '05
From Wpg, MB. Canada
So if I have the sports package.. will those bushings and nuts work for #1, #2, and #3?
post May 1, 2006 - 3:47 PM
Starcraftjunkie
Joined Nov 21, '05
K. I managed to locate the bushings for #2.. but I have a question.
For suspension arm #1.. is the bushing built in? Because if you look at the schematic picture above, there's no separate part for the bushing.
Is this the same as the knuckle (since there IS a bushing of some sort between the knuckle and the rear control arm).
Has anyone seen suspension arm #1?
post May 1, 2006 - 11:09 PM
silverspyder
Joined Jul 19, '04
From Paducah, KY
I've read about this problem all over. I have an early 94 celica.
Ever since a bodyshop installed my Eibach Sportline's, my right rear makes a clunking noise whenever I go over any kind of bump. Could this be it?
This post has been edited by silverspyder: May 1, 2006 - 11:10 PM
post May 1, 2006 - 11:24 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
take it apart and make sure nothing is loose.
post May 4, 2006 - 9:56 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
First diagram posted is of a sixth-gen Celica -- note the No. 2 (rearmost) arm with the bulge. That bulge is the toe adjuster.
The second diagram is of the fourth-gen Celica, which had the rectangular No. 1 suspension arm, instead of the cylindrical arms Toyota started using in the 1990s, and in the fifth-gen Celica specifically.
post May 4, 2006 - 11:14 PM
Starcraftjunkie
Joined Nov 21, '05
Well, I contacted 1sttoyotaparts.com and they were very helpful. Apparently, the suspension arms come with the bushings already pressed in (and is included in their price). The bushing for the front arm of the rear suspension can be purchased separated (as denoted by the part #), but the rear arm bushing is only sold along with the arm.
In case anyone else wanted to know. :b
post May 4, 2006 - 11:41 PM
LewFX
Joined Jan 28, '05
suspension arm #2
post May 4, 2006 - 11:52 PM
94celicadude
Joined Mar 28, '04
From St.Louis
well then, i guess my thread topic was not using the correct term, i had knocking noise, but clunking is what i should have used. I will try to save up and see if this works, im so tired of that noise i am about to go nuts. thanks for the info and help.
1994 GT Hatchback
1994 ST Coupe
1988 Corolla Wagon All-Trac
1999 Corvette
2008 Cobalt SS Turbo
post May 14, 2006 - 7:00 PM
blu94gt
Joined Mar 23, '05
From Kansas City
QUOTE(LewFX @ May 4, 2006 - 11:41 PM) [snapback]430321[/snapback]
suspension arm #2
is this the arm we're talking about having the noises? or just to show the toe adjuster?
I've been having the same problem. I just put my Suspension Techniques swaybars and bushings a week ago and that solved the sway bar "thud" that I had been hearing since I bought the car. Just last night I started hearing a clunking sound from the back right side, nothing seems loose on any of the parts back there. While working on the sway bar we moved the control arm with the toe adjuster, could that be the problem? or could it be my end-link ball joints? I'm not sure, but I'm guessing it has to be 1 of those options
1999 Celica GT
post May 15, 2006 - 7:26 AM
HaRv3sTeR
Joined Nov 22, '03
FINALLY NO CLUNKING!!!
it was the exhaust pipe who was hitting 2 small rods underneath...dammit never saw that before mad.gif
???sorry I dont know the name of those rods (they go from the suspension to the wheel hub)???
we discovered that those rods had some wear right under the exhaust pipe is (where the hitting was)
This post has been edited by HaRv3sTeR: May 15, 2006 - 7:27 AM
post May 15, 2006 - 12:10 PM
blu94gt
Joined Mar 23, '05
From Kansas City
Well my clunking turned out to be my endlink slightly loose on the sway bar, so we're all good!
But now my front wheel bearing that I JUST replaced is going bad, grrrrrr!
Maybe I'll just buy a new car this week lol
1999 Celica GT
post May 16, 2006 - 4:51 AM
tufy
Joined Dec 3, '03
From Cyprus
i had same proplem with my 5th gen celica too..
i changed my rear suspention top mounts.. and sound stoped.
post Feb 6, 2007 - 5:33 PM
san0
Joined Aug 1, '06
From UK - Southern Central
QUOTE(bufferdan @ Apr 3, 2006 - 10:10 AM) [snapback]417186[/snapback]
ALSO CHECK REAR SWAY BAR BUSHING! They may not look bad but they get hard and have alittle play and will cause some nasty clunking... i have found this problem on multiple 6th gens! The rubber bushings only costs 4$ each and there are two of them. To check them grab ahold of the rear sway bar under the car and yank it up and down ...if you have just alittle up and down play then you should change them.
Hi - I just ordered 2 rubber bushings, I found that the easiest way to fit them was to put the rear wheels on the ramp. Then you undo the bracket that holds the stabilizing bushes. Pop em out and replace. Takes about 30mins total for this project.
This post has been edited by san0: Feb 11, 2007 - 4:25 PM
san0.:GT-SS2:.
post Feb 11, 2007 - 12:25 PM
san0
Joined Aug 1, '06
http://www.partsamerica.com/product_images/AAP/TRW/K5248.jpg
http://www.colin99.co.uk/home_car.html
http://www.colin99.co.uk/bushes.jpg
I just replaced these and I have no clunks at last!! Woo Hoo.
This post has been edited by san0: Feb 11, 2007 - 4:27 PM
san0.:GT-SS2:.
post Feb 11, 2007 - 2:33 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
I'm getting a lot of not working pictures in this thread. Can anyone help out with that? By the way, this thread is great.
Live Free, Be Happy
3 Pages V  < 1 2 3 >
Lo-Fi Version Time is now: April 24th, 2025 - 1:17 PM
