> ? How to modify JDM tail lights ? > Clear lens
post Mar 29, 2006 - 2:16 AM
Dee-No
Joined Dec 23, '04
From Switzerland
Hi Guys. I know there was a thread about that sometime ago. I didn't find it with the search engine nor is it in the "HOW TO" Section. kindasad.gif Help!?!? Does somebody have/made a manual?
post Mar 29, 2006 - 4:05 AM
drhossa
Joined Sep 14, '04
From Germany
Junge ich erklärs dem Speedsta wies geht, das is echt kinderleicht!
Du mußt sie einfach auf der Seite einschneiden und das Glas rausschrauben, mach dir keine Sorgen das wird schon wink.gif
@amis
post Mar 29, 2006 - 4:48 AM
Dee-No
Joined Dec 23, '04
From Switzerland
jetzt hab ichs extra hier gepostet damit dus nicht siehst *grins*
Ich bin handwerklich soooo unbegabt und habe eine Scheissangst dass ich etwas kaputt mache.
post Mar 29, 2006 - 5:12 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
QUOTE(drhossa @ Mar 29, 2006 - 11:05 AM) [snapback]414982[/snapback]
@amis
es fällt mir nicht so kinderleicht zu, damit sind viele Sorgen verbunden
post Mar 29, 2006 - 7:50 AM
Dee-No
Joined Dec 23, '04
From Switzerland
@Malpaso: I will make a "How To" if my JDMs survive the procedure ;o). Date: Middle of April
post Mar 29, 2006 - 8:20 AM
malpaso
Joined Feb 3, '06
QUOTE(Dee-No @ Mar 29, 2006 - 2:50 PM) [snapback]415014[/snapback]
viel Glück! (good luck biggrin.gif)
post Mar 29, 2006 - 8:35 AM
Dee-No
Joined Dec 23, '04
From Switzerland
Quicky: (taken from Kevstir at www.celica-club.info/forum)
1. Cut (red line)
2. Remove screw
3. Remove orange lens
4. Close
This post has been edited by Dee-No: Mar 29, 2006 - 8:36 AM
post Mar 29, 2006 - 12:09 PM
Valo666
Joined May 15, '05
From Toronto
theres that way and the boiling way too. boil the tail in a pot of water untill the adhesive is soft, pry the lens back, go inside the lens, unscrew the screw and remove the amber peice and then appoxy the lens back on. Also, you could do the super ghetto way of taking a spring loaded punch to the inside of the tail where the bulb goes, crack the plastic and bring it out peice by peice with a set of plyers..lol
This post has been edited by Valo666: Mar 29, 2006 - 12:09 PM
post Mar 30, 2006 - 2:38 AM
drhossa
Joined Sep 14, '04
From Germany
Cutting is the better way I suppose cause I did it twice I didn't have any problems after I almost destroied them with other possibilities...
Dee-No das Bild beschreibt es perfekt, habs mit Silikon dicht gemacht. KLeiner Trick: bei 80° in den Ofen, dann lässt sich das Plastik leicht schneiden. Und großzügig schneiden sonst kriegst du das Glas nicht gut raus.
post Apr 19, 2006 - 11:22 AM
Dee-No
Joined Dec 23, '04
From Switzerland
yeeehaa... this weekend I'il pick up my JDMs... will post some pics of the modifying...
Lo-Fi Version Time is now: December 3rd, 2024 - 4:08 PM
