Jun 3, 2003 - 1:41 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
hahaha very similar, only more parts to get Fed over. (i think this is becoming one of the longest quoting a quote posts ever -------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Jun 3, 2003 - 4:56 AM
Enthusiast ![]() Joined May 22, '03 From Wahiawa, Hawaii Currently Offline Reputation: 0 (0%) |
I have a GT AT and when I floor it, it is very quick in the shifting department. Once it Redlines BAM!! it shifts. Also... to downshift witha push of a button can't be beat. I love it and so far, no manual has been able to use that advantage against me, not yet anyway.
Jun 3, 2003 - 3:38 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 30, '03 From Virginia Currently Offline Reputation: 0 (0%) |
Well, it seems you totally overshot my complete point. First off, it wasn't the drag-strip, as stated before. Secondly, it wasn't even a 90's model Corvette, as stated before. Thirdly, I didn't say jack about turbos. However, my point is that most manuals will shift faster, not to mention his vehicle is newer and (let's just say it) most likely more technologically advanced.
Jun 3, 2003 - 9:51 PM
your only point was "maybe hers was an auto" if you dont want to have someone take it the wrong way you should probably elaborate more. and besides it turned into a good way for people to learn some things about auto VS manual transmissions, obviously some people need to learn some more still. -------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Jun 3, 2003 - 11:40 PM
can we see the article(s) you got that from? its not that im doubting you, i do know the fastest cars all do eventually need to be converted to autos... i would just really like to read the article. and also as i stated before each one is twin turboed. my apologies about the street legal thing originally i thought you said stock street legals, but then i read 7 seconds and that that isnt right... my bad, but that still doesnt prove your point. -------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Jun 3, 2003 - 11:53 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
OOOK.
On an automatic transmission (which I have) a neutral drop is pure stupid! Just power brake it a little (2500k) and you're good. My first car was a 1986 corvette. It had about 225hp and 330 Ft-lbs of torque. Now, when I wanted to play, I could burn the tires for about 16-20 feet... no kidding. Once I was honestly going 45mph and Floored it and the rear end cut loose and I was all over the road. Point is, after 1984, the vette would run high 13's to low 14's. You see, it cost almost 30000 new, so it had to have power. The engine that bashed the vett's name was the 'crossfire' from 78-84,, or was the 8 a L-70 something... Pont is the L-88 was a great engine which was the mainstay of GM until the LT-1 came out. If you beat that car, it had some serious problems. Jon |
Jun 4, 2003 - 8:16 AM
The article is in the last October Issue of "Turbo & High-Tech Performance".
Jun 4, 2003 - 1:30 PM
cool thanks -------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Jun 4, 2003 - 4:44 PM
![]() Enthusiast ![]() ![]() Joined Nov 11, '02 From Ohio Currently Offline Reputation: 0 (0%) |
This might help...... 1984 FACTORY BASE PRICE- $23,360 PRODUCTION TOTAL- 51,547 CURB WEIGHT lbs- 3088 ENGINE DATA Displacement- 350 cubic inch V-8 Compression Ratio- 9 to 1 Horsepower- 205 Torque lbs-ft- 290 Fuel Injection- Crossfire TRANSMISSION- 4+3 speed manual standard. 4 speed automatic available at no cost. 1985 FACTORY BASE PRICE- $24,873 PRODUCTION TOTAL- 39,729 CURB WEIGHT lbs- 3088 ENGINE DATA Displacement- 350 cubic inch V-8 Compression Ratio- 9 to 1 Horsepower- 230 Torque lbs-ft- 330 Fuel Injection- Tuned Port 1986 FACTORY BASE PRICE- $27,207 (coupe) $32,032 (convertible) PRODUCTION TOTAL- 39,729 (27,794 coupes) (7315 convertibles) CURB WEIGHT lbs- 3086 ENGINE DATA Displacement- 350 cubic inch V-8 Compression Ratio- 9.5 to 1 Horsepower- 230 Torque lbs-ft- 330 Fuel Injection- Tuned Port 1987 FACTORY BASE PRICE- $27,999 (coupe) $33,172 (convertible) PRODUCTION TOTAL- 30,632 (20,007 coupes) (10,625 convertibles) CURB WEIGHT lbs- 3098 ENGINE DATA Displacement- 350 cubic inch V-8 Compression Ratio- 9.5 to 1 Horsepower- 240 Torque lbs-ft- 340 Fuel Injection- Tuned Port TRANSMISSION- 4+3 speed manual standard. 4 speed automatic available at no cost. 1988 FACTORY BASE PRICE- 29,489 (coupe) 34,820 (convertible) PRODUCTION TOTAL- 22,789 (15,832 coupes) (7407 convertibles) CURB WEIGHT lbs- 3157 ENGINE DATA Displacement- 350 cubic inch V-8 Compression Ratio- 9.5 to 1 Horsepower- 245 Torque lbs-ft- 345 Fuel Injection- Tuned Port TRANSMISSION- 4+3 speed manual standard. 4 speed automatic available at no cost. 1989 FACTORY BASE PRICE- n/a (coupe) n/a (convertible) PRODUCTION TOTAL- 30,632 (20,007 coupes) (10,625 convertibles) CURB WEIGHT lbs- 3120 ENGINE DATA Displacement- 350 cubic inch V-8 Compression Ratio- 9.5 to 1 Horsepower- 245 Torque lbs-ft- 345 Fuel Injection- Tuned Port TRANSMISSION- 6 speed manual, 4 speed automatic available at 1990 FACTORY BASE PRICE- 31,979 (coupe) 37,264 (convertible) $59,495 (ZR1) PRODUCTION TOTAL- 23,646 (16,016 coupes) (7630 convertibles) CURB WEIGHT lbs- 3120, 3470 ZR1 ENGINE DATA Displacement- 350 cubic inch V-8 Compression Ratio- 9.5 to 1 Horsepower- 245, 250, (375 ZR1) optional Torque lbs-ft- 345, 350, (370 ZR1) optional Fuel Injection- Tuned Port TRANSMISSION- 6 speed manual, 4 speed automatic available at no cost. 1991 FACTORY BASE PRICE- $31,979 (coupe) $37,264 (convertible) $65,318 (ZR1) PRODUCTION TOTAL- 20,639 (14,967 coupes including 2044 ZR1's) (5672 convertibles) CURB WEIGHT lbs- 3120, 3470 ZR1 ENGINE DATA Displacement- 350 cubic inch V-8 Compression Ratio- 9.5 to 1 Horsepower- 245, 250, (375 ZR1) optional Torque lbs-ft- 345, 350, (370 ZR1) optional Fuel Injection- Tuned Port TRANSMISSION- 6 speed manual, 4 speed automatic available at no cost. 1992 FACTORY BASE PRICE- $33,635 (coupe) $40,145 (convertible) $65,318 (ZR1) PRODUCTION TOTAL- 20,479 (14,604 coupes including 502 ZR1's) (5875 convertibles) CURB WEIGHT lbs- 3223, 3470 ZR1 ENGINE DATA Displacement- 350 cubic inch V-8 Compression Ratio- 10.2 to 1 Horsepower- 300, (375 ZR1) optional Torque lbs-ft- 330 (370 ZR1) optional Fuel Injection- Multi-port TRANSMISSION- 6 speed manual, 4 speed automatic available at no cost. Most likely it was an '84....however my dad has a '85 and I know what you're talking about when you say its slow. It would seem that going from 135 (celi) to 230 (vette) would be a huge difference. However it isn't. For some reason it doesn't seem to go. Anyway...I listed all the eighties. There was no '83..(well there was but there is only one left driving) and the 82, 81, 80 were all the C3s. Different body style. I just listed the 90, 91 ,92 to complete the C4 generation. Who knows though...she might have not really been trying..or something could have been wrong with the car...and hell you could have just beat it...anyway hope this shines some light on the discussion. |
Jun 4, 2003 - 5:08 PM
![]() Enthusiast ![]() ![]() ![]() Joined Oct 31, '02 From Boise, ID Currently Offline Reputation: 2 (100%) |
Sweet thanks. I'll just tell people I beat a vette, I won't tell them the year!
Thanks for the help everyone! -------------------- ![]() psalm 69 |
Jun 5, 2003 - 12:47 AM
Also, on mine it was rev-governed at 2500 rpms until it got up to 200 degrees with the engine. Maybe it was cold. And my 86 scared the hell out of me as far as speed goes.
Jon |
Jun 8, 2003 - 2:32 AM
Enthusiast Joined Apr 15, '03 From Lonestar state Currently Offline Reputation: 0 (0%) |
I guess a lot of peeps here are pretty right about the vettes from the 80's. I used to have this neighbor who'selling me his 86 vette for just $800 and its very clean and well kept. His main reason for selling it cheap is because it doesn't have that much power compared to other vettes according to him. He even got his ass whopped by 6 cyl mustangs and Rs Camaros. He had high expectations when he first bought it from a used car lot. After a week, he brought it to his friend who is a mechanic and had it tuned up and replaced everything that needs to be replaced. Even put an after market and performance parts for it. When the 2000 vettes came out on the market, one of his friends purchased one, since he is interested on buying one for him self he went out with him one Saturday eve to cruise, On their way to the club on the expressway they decided to pick on an IS300 heading on their direction. He told me that as soon that the IS300 found out that they were trying to race him, the driver I guess just flooored it and smoked their asses. They were trying to catch up he said but the IS300 is long gone. He concluded that time that he'd rather stick with a Japanese car.
Jun 18, 2003 - 12:57 AM
Enthusiast ![]() Joined Feb 16, '03 From Baton Rouge, La Currently Offline Reputation: 0 (0%) |
do you just not want to worry about a clutch, because you can't handle a clutch ?...most people that drive sticks, drive them because... 1. YOU ARE IN CONTROLL 2. YOU TELL THE CAR WHAT TO DO 3. THEY ARE JUST TO DAMN FUN 4. IT MAKES RACING EASIER and INTRESTING (how?)....well with an automatic you can't slow for a corner and then punch it and expect INSTANT power.. but wiht a standard you can, you slow, clutch, shift and punch it, BAM power on tap !...you just don't have that with an automatic. thats how I feel on the subject |
Jun 18, 2003 - 1:05 AM
quit racing metros and race real cars, my car smokes auto celicas, sixth gen's 7th gens, its not a MONSTER SPEED DEMON, but it has it moments.....but like all cars they have there weak points like when im racing my friend who has a VR-4 galant, when we race he kills me because my gears are all short compared to his, so i loose, but i can win if i catch him at a bad spot like third.. its just that every car has a strong and weak points. |
Jun 18, 2003 - 3:34 AM
and in the time you took to shift while turning, someone in an auto will have already mashed the throttle, and the tranny would have gone into the appropriat gear and the power would be on just as fast. you may not have the same control as with 5spd, but if you understand how your tranny works, you can work around the disadvantages. i like the fact that i can concentrate on making the turn, instead of shifting as im turning, watching my speed and clearances and not turning too hard and losing control. its all about personal preference, when im driving a 5spd, i tend to go into a turn in 2nd and shift after comming out. -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Jun 18, 2003 - 9:11 AM
![]() Enthusiast ![]() ![]() ![]() Joined Apr 20, '03 From Chicago Currently Offline Reputation: 0 (0%) |
Nah, for rally, or autocross you REALLY want a manual like BlackandTan says. But for drag, auto is just as good, and sometimes better. Depends on what your game is.
Jun 19, 2003 - 11:01 AM
Enthusiast ![]() Joined May 15, '03 From NYC, Queens Currently Offline Reputation: 0 (0%) |
first being fast on the drag doesnt necessarily mean it's fast all over. make dat **** race rally and it wont b able to handle it. less wif an auto trans. about auto's being fast on corners????? give me a break. downshift wif a manual (real downshift, not the ****ty i step on the break, slow down, step on the clutch, go down on gear and step on the gas ****) and turning a corner cant get any faster.
| Lo-Fi Version | Time is now: June 25th, 2026 - 9:47 AM |
