> important question on the syncho for tranny, what happens????
post Apr 1, 2006 - 1:21 PM
pnoywitmustrdsau...
Joined Mar 28, '05
From California
can you run on bad synchos if that is the problem? i said harsh engagement in the first three gears? will i damage it more if i do?
post Apr 1, 2006 - 1:52 PM
i kind of doubt its your synchros. i would understand if one of them went, but for all 3 gears to have harsh engagement, there must be soemthing else going on. im willing to bet that you have a clutch related issue.
post Apr 1, 2006 - 2:28 PM
pnoywitmustrdsau...
Joined Mar 28, '05
From California
really? i have a spare clutch from act and its just waiting but i was waiting just for the clutch to wear out then i would install it? how did you come to that conclusion?
post Apr 1, 2006 - 2:39 PM
because clutches can cause shifting issues too. most people will wear out a syncho or two, but you really would have to beat the crap out of the tranny and have very high milage to toast 3 of them.
you can also try doing a clutch pedal adjustment, and changing to pensoil synchromesh tranny oil. it might help you.
post Apr 1, 2006 - 2:52 PM
pnoywitmustrdsau...
Joined Mar 28, '05
From California
i used the valvoline synchomesh gear oil recommended 75w-90, my dad suggested messing with the clutch fluid, that there might not be any fluid but thanks with the info.
post Apr 1, 2006 - 3:37 PM
kenjamatic
Joined May 20, '05
From sacramento, ca
i was having a hard time putting the car into gear a couple weeks ago and recently i had to force it in...when driving it's like i'm not pressing the clutch at all and had to force it into every gear...i got the clutch changed and my mechanic told me that my clutch had broke into pieces(i don't know how) and that was the reason why...got my act street clutch in and it's smooth now(next thing now is to break in the clutch)...so you might have a similar problem too....
post Apr 1, 2006 - 10:42 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
i must have misread, i thought he was ONLY having problems with 1-2 which led me to think it was a synchro.
Lo-Fi Version Time is now: December 1st, 2024 - 1:41 AM
