> Drive shaft/axle, any difference between 94-95 and 96-98?
post Apr 2, 2006 - 11:40 PM
J-TYPE
Joined Mar 16, '05
From Toronto, Ontario
hi, i'm having a big problem here, my driver side drive shaft/axle is making a really bad and annoying knocking, scraping sound. the noise does not happen all the time though but when it does it really sounds bad like the drive shaft/axle is about to snap or something. i've went through 4 rebuilt drive shafts already and all of them made a really bad knocking noise or snaped on the ends. so i was wondering if the drive shafts are different between the years 94-95 and 96-98, just thought i might try the newer year if there was a difference and see how that goes. i have the stock 5sfe engine and tranny. hopefully if someone has had the same problem can let me know what they did or what i should do. really need your help right now guys, thanks!
post Apr 3, 2006 - 7:46 AM
MaX
Joined Nov 7, '05
From Brisbane, Australia
havent had that problem, but look around for some billet driveshafts, that will make a difference
post Apr 3, 2006 - 1:57 PM
J-TYPE
Joined Mar 16, '05
billet driveshaft? what is the difference with those?
Lo-Fi Version Time is now: November 29th, 2024 - 6:39 PM
