> install a fog light, install a fog light
post Apr 3, 2006 - 4:42 AM
the_rapture
Joined Mar 10, '06
From Australia
can someone please tell me how to install a fog light thank in advance
post Apr 3, 2006 - 8:41 AM
bojangles_8686
Joined Nov 12, '02
From Baltimore, MD
Which part of the install do you need help with? That would help out a little bit smile.gif
post Apr 3, 2006 - 10:24 AM
JFrost9
Joined Aug 27, '05
From Texas
dont wanna sound like rude, but if you'll search you will find a ton of info on this. There have been a few post about mounting them lately, and there was a post awhile back on the wiring and what not.
post Apr 3, 2006 - 8:12 PM
Valo666
Joined May 15, '05
From Toronto
easiest way ive found, crawl under ur car, remove the front splash sheild, remove the 2 far bolts for the rear of the splash sheild. Get a drill, make ur mounting point, drill piolet hole, go to bigger sided bit, use a self tapping screw, screw in the mount, attach the fogs, run your wires, turn em on and have fun. mine took me about 30 min to install and about 40 min to wire up.
post Apr 3, 2006 - 9:26 PM
Manta5x
Joined Jul 7, '04
From Maryland
get a remote controll harness relay, that way you dont have to run a wire through the firewall.
you can turn the lights on and off with a remote
This post has been edited by Manta5x: Apr 3, 2006 - 9:31 PM
post Apr 3, 2006 - 11:48 PM
the_rapture
Joined Mar 10, '06
From Australia
Thank guys for the help i think i get the harness it be easier that way
Lo-Fi Version Time is now: February 17th, 2025 - 1:46 AM
