![]() Enthusiast ![]() Joined Mar 20, '06 From Ireland Currently Offline Reputation: 0 (0%) ![]() |
Need a little help. Is there any way possible that you can remove a tint from windows. The tint on my back 3 windows are too dark and i was wondering if there is any thing like paint tinner that could be used to get rid of the tint?
Thanks This post has been edited by alf15: Apr 5, 2006 - 5:33 AM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) ![]() |
you should be able to just peal it off, its not ganna be easy but if you can get a good grip and slowly pull it will come off. gana tare on you and be a pain but with a sharp blade it will all pull off, its the glue that needs a solvant, and for thar i would use goofoff.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) ![]() |
QUOTE(alf15 @ Apr 5, 2006 - 12:33 PM) [snapback]418015[/snapback] Need a little help. Is there any way possible that you can remove a tint from windows. The tint on my back 3 windows are too dark and i was wondering if there is any thing like paint tinner that could be used to get rid of the tint? Thanks If it's your window tint that kind of metal coating I don't think you will able to get it off. If it's some adhesive foil I belive you would be able to flick it off... -------------------- No more replicas... This is evolution... This is SS-four :)
![]() ________[Featured Celica of 6gc.net @ 2010]_________ |
i think the rear side windows are that film tint so that will peel off like creis said, but im nearly sure the rear window is sprayed...so there is no other way off getting rid of the tint on the rear unless i replace the hole rear window
![]() Enthusiast ![]() ![]() ![]() Joined Feb 24, '05 From Pittsburgh, PA Currently Offline Reputation: 0 (0%) ![]() |
Theres some kind of window tint dissolver or something i think. Ill try and look for it. -John
Lo-Fi Version | Time is now: April 23rd, 2025 - 6:57 PM |
