> New rotors, Should I replace my pads too?
post Apr 6, 2006 - 12:33 PM
root
Joined Feb 26, '06
From Bowling Green, OH
In the midst of replacing my half-shafts, I decieded to resurface my rotors. The guy at Ohio Automotive mic-ed em and told they were shot, so now I need to pick up some new rotors. My question is: Do I need to replace my pads too? They look like they still have plenty or meat left on them, as they were just replaced this past winter. Will my new rotors take on the same grooves that were on the last ones? Also, do i really need to use that pad coating that reduces squeels?
post Apr 6, 2006 - 12:46 PM
bindertch
Joined Aug 18, '04
From Silverdale, WA
If the rotor has grooves in it then that usualy means that the pads are so worn that they are rubbing metal to metal. If the barakes sqeak realy bad when stopping then this is guaranteed. As mosty brake shops will recomend to replace the pads with the rotors. But if there is still a lot of pad left and the surface is flat to the rotor then it isn't needed.
This post has been edited by bindertch: Apr 6, 2006 - 12:47 PM
post Apr 6, 2006 - 1:10 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
replace the pads with the new rotors, anti-squeel spray (grey stuff) the surface of the rotors, anti-squeel (red goop) the back of the shims. there are some used rotors and pads in the b/s forum (im selling some laugh.gif )
post Apr 7, 2006 - 2:56 AM
pandakid
Joined Feb 12, '06
From Fresno CA
yea get chermic IMO
post Apr 7, 2006 - 7:18 AM
it is always a good idea to replace your pads if your putting on new rotors...they are relatively cheap and its just one more step to protect you in the long run smile.gif
Lo-Fi Version Time is now: December 1st, 2024 - 2:14 AM
