> SSIII Beams into a 97 GT Convertible?
post Apr 7, 2006 - 12:56 AM
JDMsw20
Joined Mar 25, '06
From Bayside, NY
Hi guys, I currently have a Beams front clip from a st202 SSIII. I was wondering which trim of the 6 Gen will be the best bet, and have the least modifying to make the swap work. I'm currently looking at a 97 GT convertible 5spd that houses a 5sfe. Just by modify mr2's I know that anything that houses a 5sfe originally can support a 3s engine family with minor or no modifications needed.
post Apr 7, 2006 - 1:05 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
5spd. GT is the way to go. Hard top or vert is up to you.
I will return one day.
post Apr 7, 2006 - 10:24 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
^what he said
post Apr 7, 2006 - 11:10 PM
JDMsw20
Joined Mar 25, '06
From Bayside, NY
sweet I kinda figured that much, but just needed a 2nd opinion !
post Apr 7, 2006 - 11:44 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
The way I look at this, it's better to put it in a hatch. The vert is something like 200lbs heavier and the lack of roof makes the car less stiff and handle a little worse. This really doesn't matter most of the time, but if you're going to put a high powered NA motor in, it does. Most NA applications are for cars that are built to be quick and snappy handling. I just think putting it in a vert is starting a little handicapped. But, it might not be as bad I'm thinking.
Live Free, Be Happy
post Apr 8, 2006 - 6:12 AM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(Bigmeanbulldog55 @ Apr 7, 2006 - 11:44 PM) [snapback]419018[/snapback]
Have you ever taken a ride in any 6gc vert? If so, have you ridden in one with high power? 200hp at the flywheel can be handled in these cars with NO problem.
post Apr 8, 2006 - 8:05 AM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
post Apr 8, 2006 - 1:25 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(jgreening @ Apr 8, 2006 - 7:12 AM) [snapback]419088[/snapback]
It's simple engineering, the vert has less support structure. The vert isn't going to have the rigidness of a coupe or hatch. And the vert is heavier. I'm sure it can handle all the power. That really isn't an issue. I'm sure your vert makes a good drag car, but a coupe or hatch with the same mods should go a little faster and turn a little better. I have never ridden in a 6gc vert.
Live Free, Be Happy
post Apr 8, 2006 - 1:50 PM
Tech9ine
Joined Jun 28, '05
From MB, Canada
does that mean your going to have a 96+ bumper for sale????
post Apr 8, 2006 - 8:23 PM
CelicaZR
Joined Mar 25, '05
From Sydney, Australia
Doesnt the convertible has a stiffer chassis than the hatch and coupe?
6GC 4 Life Baby!!!
post Apr 8, 2006 - 9:47 PM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE(CelicaZR @ Apr 8, 2006 - 6:23 PM) [snapback]419272[/snapback]
why would you think that?
post Apr 8, 2006 - 10:29 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(Hanyo @ Apr 8, 2006 - 10:47 PM) [snapback]419291[/snapback]
He probably heard that the vert was less than a hatch or coupe and then got it backwards. Kind of like messing up a right and a left. It happends all the time.
Live Free, Be Happy
Lo-Fi Version Time is now: December 1st, 2024 - 9:02 PM
