Rear ST axels |
Rear ST axels |
Apr 9, 2006 - 10:00 PM |
Enthusiast Joined Oct 16, '05 From omaha,nebraska Currently Offline Reputation: 0 (0%) |
Will the rear axels fit right up to a st from a gt, with the disk brakes?
Apr 10, 2006 - 7:59 AM |
Enthusiast Joined Dec 16, '02 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) |
QUOTE(Hawkins Corp @ Apr 9, 2006 - 11:00 PM) [snapback]419604[/snapback] Will the rear axels fit right up to a st from a gt, with the disk brakes? Not sure exactly waht you mean, but if you are asking if the GT rear disks fit on the ST rears with no problem, then yes. Just need the backing plate, calipers, rotors, parking brake internals, and pads. |
Apr 10, 2006 - 7:06 PM |
i ment the whole assembly axels and all.
Apr 10, 2006 - 7:54 PM |
LMAO...celicas don't have rear axels.......
Apr 10, 2006 - 8:35 PM |
Then what are they called?
Apr 10, 2006 - 8:46 PM |
these should give you the idea of how it works basically you have in the 2nd picture a cast iron knuckle that the brake/wheel assembly gets bolted onto (this is stationary non rotating) its connected to "arms" to hold it into place as well as the strut/spring on the vertical axis... in the last picture you see the back side of the hub...this is what the wheel studs and bearing assembly, and spindle are housed on...this bolts to the knuck via 4 bolts... (same GT and ST) in the first picture you can see the hub/drum brake/strut all mounted up onto the knuckle and car... the assembly in picture 2 is wat allows the rear wheels to rotate on the knuckle....since we are FWD we have no need for axels as the rears "free spin" |
Apr 15, 2006 - 1:58 AM |
Enthusiast Joined Mar 22, '06 From Wesley chapel, Florida Currently Offline Reputation: 13 (93%) |
hay i know that this is off of what you were talking about but does the brake line work on the disk from the drum?
Apr 15, 2006 - 5:48 PM |
QUOTE(twolownissan2002 @ Apr 15, 2006 - 2:58 AM) [snapback]421787[/snapback] hay i know that this is off of what you were talking about but does the brake line work on the disk from the drum? no. You would need a different (GT) brake line. -------------------- |
Lo-Fi Version | Time is now: November 27th, 2024 - 11:47 AM |
