taillights bolts, ive oevr tightened them |
Apr 10, 2006 - 5:09 PM |
Enthusiast Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) |
hey all....i overtigtened the LH tailights..and the next time i try to chnage a rverse bulb....the 2 bolts came off..i mean the 10mm nut n bolt came off away from the tails...my question is....does any1 knows how to get those darn things off?....ive tried using a plier hold it real tight n use the 10mm wrench to turn it..but to no conclusion..can any1 help?....
Apr 10, 2006 - 6:33 PM |
Enthusiast Joined Jun 30, '03 From O-town, FL Currently Offline Reputation: 0 (0%) |
PB Blaster gets anything loose.
Apr 11, 2006 - 10:51 PM |
ill get pics of this issue in the weekeend...ty
Apr 11, 2006 - 11:00 PM |
Enthusiast Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
I have been there. The nuts have a tendency to strip the bolts very easily, the the bolt just rips out from the plastic. In the past, I have used a special aircraft glue. Sometimes, u just got get a new set of taillights(used).
I know, I have been through two sets already. |
Apr 11, 2006 - 11:55 PM |
*sigh*...
but madmods how u took them bolts off?.... -------------------- |
Apr 12, 2006 - 12:12 AM |
1. buy pb blaster
2. spray on bolts 3. wait 4. twist off 5. ??? 6. profit -------------------- |
Apr 12, 2006 - 1:19 AM |
QUOTE(DeW_H0e_GT @ Apr 12, 2006 - 4:55 AM) [snapback]420507[/snapback] *sigh*... but madmods how u took them bolts off?.... Visegrips and wrench |
Apr 19, 2006 - 6:47 AM |
Enthusiast Joined Mar 29, '06 From Hull, UK Currently Offline Reputation: 0 (0%) |
As madmods said, molegrips and a vice to get the nut off the bolt, then I would try making the hole in the plastic so that it is wider on the inside than the outside then just use a hot glue gun to stick the bolt back into the plastic, maybe even crimp a small washer onto the knurled end of the bolt and then glue it so that it won't just pull out of the glue.
Hope it helps. Tried drawing a picture with characters on here but it doesn't like it. I will do one and photobucket it if necessary. This post has been edited by vsideboy: Apr 19, 2006 - 6:50 AM |
Apr 19, 2006 - 8:25 AM |
thanx bro...
Lo-Fi Version | Time is now: December 4th, 2024 - 6:02 AM |
