Plug Wires, might be a dumb question... |
Apr 10, 2006 - 11:09 PM |
Enthusiast Joined Jan 3, '04 From knoxville, tn Currently Offline Reputation: 0 (0%) |
My car has recently been only getting about 26-27 mpg when I drive in the city/highway, but still gets ~34 when it's highway only.
I'm thinking it might be the plug wires...on the wires it has "1996" My question is, is that the year those wires were made and most likely put on my car, or do they have "1996" because that's the year of car I have... They still look okay, I guess, but I don't really know what to look for when wires go bad. The plugs themselves are only about 25-30k old...so they should still be ok, I believe. If it turns out the wires aren't the problem, and they say 1996 b/c thats the year car they're for, then any other ideas? The O2 sensor was replaced a couple months ago. -------------------- "Somebody give me a fire...so I can burn this city down." - Widespread Panic
Apr 11, 2006 - 1:55 AM |
Enthusiast Joined Nov 21, '05 From Wpg, MB. Canada Currently Offline Reputation: 3 (100%) |
26-27 is pretty good for the 6th gens, I think.. depends alot on if it's stop and go traffic in the city.
Apr 11, 2006 - 2:52 AM |
Enthusiast Joined Mar 21, '06 From Burnsville, MN Currently Offline Reputation: 0 (0%) |
Plug wires have a minor role in fuel economy. If you had a problem with the wires, the engine would misfire or stumble at idle or under load. Besides, Toyota wires are really good. I've seen original wires w/ 150K+ miles on them, still going strong!! However...
Start with the basics: engine air filter and PCV valve. If both of those are okay, run some fuel injector cleaner through (STP makes a few that just pour in the tank). Otherwise I use an engine treatment that works really well. It's made by Automotive Restore Products. It's available at any local auto parts retailer. It's in a little silver can (easily recognized). Add that to the oil when you change it; it works like magic!! After that, check the throttle body. If it's dirty, clean it!! After that....I'll have to agree that 26-27mpg is pretty good for a ten year old car!! -Speed |
Apr 11, 2006 - 8:02 AM |
when was the last time you changed your air filter, spark plugs, dizzy cap & rotor?
13.6@108MPH, 5SFTE Powered |
Apr 11, 2006 - 8:34 AM |
Enthusiast Joined May 17, '03 From Florence, KY Currently Offline Reputation: 0 (0%) |
My car is the exact same way and I've done everything that's been listed here. Keep off the gas as much as possible in city driving. That's really good for actual mileage. The EPA estimates are usually way overrated and they're talking about revising the way they're estimated.
Apr 11, 2006 - 10:17 AM |
I've never changed the distributor cap and rotor...
I have done the air filter recently, pcv valve, spark plugs maybe 30k ago One thing, the car does idle wierd right at start up..kinda like it does for a cold start, even when it's not cold. And when it idles once it gets to normal, it drops to right below where it needs to be idling. -------------------- "Somebody give me a fire...so I can burn this city down." - Widespread Panic
Apr 11, 2006 - 3:32 PM |
id do the cap and rotor before anything else, and clean or replace your air filter.
Apr 11, 2006 - 3:54 PM |
1. accelerate more gently
2. try to stop less 3. inflate your tires a few psi higher the 3 things will have the biggest impact on fuel milage. -------------------- |
Lo-Fi Version | Time is now: November 30th, 2024 - 4:27 PM |
