![]() Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) ![]() |
ok i just intalled my new turbo kit and it seems to be running a little rich , my kit includes , t3 turbo in a 60 trim , wastegated at 7 psi , 89 ford probe injectors, 3 in intake pipe& down pipe back is also 3 in, 12:1 fmu , walbros 255 fuel pump, type rs bov,and a costome mount side intercooler, i have all the other little thing for the kit as well, i retarded my timming by 6 degrees and it just wont smooth out
![]() ![]() This post has been edited by trd94: Apr 11, 2006 - 2:46 AM -------------------- ![]() |
you retarted your timing WAY too much..
that FMU is a VERY bad idea...under just 2 lbs of boost, your gonna be raising your fuel pressure 24lbs. thats nuts...your fuel pump and injectors will never be able to keep up with the demand. -------------------- Former Team 5SFTE pro member ;)
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) ![]() |
QUOTE(trd94 @ Apr 11, 2006 - 12:45 AM) [snapback]420095[/snapback] ok i just intalled my new turbo kit and it seems to be running a little rich , my kit includes , t3 turbo in a 60 trim , wastegated at 7 psi , 89 ford probe injectors, 3 in intake pipe& down pipe back is also 3 in, 12:1 fmu , walbros 255 fuel pump, type rs bov,and a costome mount side intercooler, i have all the other little thing for the kit as well, i retarded my timming by 6 degrees and it just wont smooth out ![]() ![]() yeah man, are you using a safc or something to regulate fuel? |
QUOTE(presure2 @ Apr 11, 2006 - 5:19 AM) [snapback]420107[/snapback] you retarted your timing WAY too much.. that FMU is a VERY bad idea...under just 2 lbs of boost, your gonna be raising your fuel pressure 24lbs. thats nuts...your fuel pump and injectors will never be able to keep up with the demand. why is this fmu bad ,i think nik used a 12:1 on his 7afte with no problems ![]() ![]() QUOTE(CheesyLobster @ Apr 11, 2006 - 5:58 AM) [snapback]420109[/snapback] QUOTE(trd94 @ Apr 11, 2006 - 12:45 AM) [snapback]420095[/snapback] ok i just intalled my new turbo kit and it seems to be running a little rich , my kit includes , t3 turbo in a 60 trim , wastegated at 7 psi , 89 ford probe injectors, 3 in intake pipe& down pipe back is also 3 in, 12:1 fmu , walbros 255 fuel pump, type rs bov,and a costome mount side intercooler, i have all the other little thing for the kit as well, i retarded my timming by 6 degrees and it just wont smooth out ![]() ![]() yeah man, are you using a safc or something to regulate fuel? i dont have a safc yet ![]() ![]() -------------------- ![]() |
12:1 is an extremley high rise rate...for every pound of boost, your raising fuel pressure by 12lbs.
id REALLY get away from the fmu, get a set of properly sized injectors and a 2 bar map sensor from an alltrac or mr2T, and somthing like the SAFCII or even better emanage or SMT6 or 7 to control them. thanks for the props =) :edit: the probe injectors are what 330cc or somthing? thats actually pretty close to what you need. what are you doing about your stock map sensor? if you were to go to a 2 bar map, you could get rid of the FMU, and use somthing like the SAFCII to tune out your fuel curve. with the option of using a better matched turbo to the car, you ST guys should really be looking into maximizing everything else in the setup to make it more durable, and bulletproof. the FMU is really old school stuff, and really should be abandoned for our setups IMO. there are much better, safer, more controlable ways to do it. -------------------- Former Team 5SFTE pro member ;)
QUOTE(presure2 @ Apr 11, 2006 - 8:05 AM) [snapback]420132[/snapback] 12:1 is an extremley high rise rate...for every pound of boost, your raising fuel pressure by 12lbs. id REALLY get away from the fmu, get a set of properly sized injectors and a 2 bar map sensor from an alltrac or mr2T, and somthing like the SAFCII or even better emanage or SMT6 or 7 to control them. thanks for the props =) :edit: the probe injectors are what 330cc or somthing? thats actually pretty close to what you need. what are you doing about your stock map sensor? if you were to go to a 2 bar map, you could get rid of the FMU, and use somthing like the SAFCII to tune out your fuel curve. with the option of using a better matched turbo to the car, you ST guys should really be looking into maximizing everything else in the setup to make it more durable, and bulletproof. the FMU is really old school stuff, and really should be abandoned for our setups IMO. there are much better, safer, more controlable ways to do it. the map sensor i used check valves to bypass it (i know very old school ) i will look in to a differant map sensor ![]() ![]() -------------------- ![]() |
i think that you should be fine with the 12:1 fmu, that is what i am using. and i am using check valves (i haven't heard of a 2 bar map used on a 7afte successfully without a code) I think that you should get a safcii to manage those injectors, i think thats the problem.
Enthusiast ![]() Joined Oct 17, '04 From St Louis, MO Currently Offline Reputation: 0 (0%) ![]() |
*shakes head*
so you have a 1 bar map, 50% larger injectors and an FMU ? are you still running oil in the motor ? or is your oil all fuel ? you're throwing in 50% more fuel at idle, and 250% more fuel at 7psi so unless you have a 3.0 litre, making 420 crank hp @ 7psi then your fueling is incorrect. Throwing a code doesn't mean the 2 bar setup is wrong... it depends what the code is... if you put a 2 bar sensor on and 800 cc injectors you may get a 'rich code' ... if u put smaller than needed injectors on with a 2 bar you may get a 'lean code' ... so unless you're actually getting a code for the map sensor ... and have verified that is the code that you're getting on a 2bar setup... then the problem would be the tune and not the use of the 2bar sensor -nuke -------------------- 2005 MB C200 Kompressor- K&N, Apexi WS2 Catback, DIY Voltage stabilizer, Intrax Springs, H&R RR swaybar, VDO Boost Gauge @ 6psi, Greddy L7 plugs, +0 Rear tires
To Do: E-manage Ultimate tuned up to 12psi |
thanks for chiming in on that nuke, i dont know the figures, so i dont like to quote amounts...but yea, thats the genral idea i was trying to get across to him.
and, just be cause the check valve/ FMU thing WORKS, dont mean its the best way..trust me, the 2 bar map and properly sized injectors will go ALONG way to helping your car run better. -------------------- Former Team 5SFTE pro member ;)
so you are saying that a 2bar map wouldn't throw a code at all if you are running correct ratios? what about the ecu seeing pressure??
![]() Enthusiast ![]() ![]() Joined Jan 13, '06 Currently Offline Reputation: 0 (0%) ![]() |
like nuke and cheesy said:
it runs like **** because you need to turn those injectors down at idle. get a safc. i have the old school five knob kind and it works well. the new ones you can adjust for TP and that will be really helpful. what 2bar would work for the 7afte? also TRD94 posts some pics of your set up. ![]() This post has been edited by southwest2118: Apr 11, 2006 - 11:42 PM |
QUOTE(southwest2118 @ Apr 12, 2006 - 12:41 AM) [snapback]420501[/snapback] what 2bar would work for the 7afte? since the ST and the GT have the same stock MAP sensor, switching to an all-trac or MR2 turbo (both 3sgte) 2 bar map would work just fine for a 7afte build like Manny (presure2) is saying. -------------------- |
ok guys i thank you for all your help. right now i went back to my old set up stock injectors ,12:1 fmu idle is back where it belongs i turned the boost down to around 4 psi ,i am just going to wait until i get my safcII and look in to this two bar map sensor, i plan on making good hp but in the same time i dont want to blow a piston out the side. thanks again for the help and please keep it coming
![]() ![]() QUOTE(southwest2118 @ Apr 11, 2006 - 11:41 PM) [snapback]420501[/snapback] like nuke and cheesy said: it runs like **** because you need to turn those injectors down at idle. get a safc. i have the old school five knob kind and it works well. the new ones you can adjust for TP and that will be really helpful. what 2bar would work for the 7afte? also TRD94 posts some pics of your set up. ![]() i do not know how to post pic but i do have a couple in my profile , if any one would like to post them for me go ahead ![]() This post has been edited by trd94: Apr 12, 2006 - 2:36 AM -------------------- ![]() |
Some simple math... example
stock hp = 100hp.... target hp = 400hp stock injector = 200cc/min ideal injector = 400/100 * 200 = 800cc/min roughly: cc/min = desired wheel hp *1.5 200whp = 350cc/min 300whp = 450cc/min << the figure most 3sgte guys quote 400whp = 600cc/min This is all for 4 cylinder cars Fuel pressure example stock fuel pressure = 40psi new fuel pressure = 80psi fuel pressure ratio = 80/40 = 2.0 flow ratio = square root ( fuel pressure ratio) = square root (2.0) = 1.41 1.41 is 141% so 41% more than stock ... so if you had 200cc injectors @ 40psi, and you got a new fuel pressure regulator set @ 80psi then you effectively now have 200*1.41 =282cc/min injectors 282cc/min /1.5 = ~188whp worth of fuel FMU example. you have 300hp stock, you want to put on a turbo (that according to the compressor map) says that you can make 520hp @ 8psi (according to the chart) fuel flow ratio = horsepower ratio fuel flow ratio = 520/300 = 1.7333 fuel pressure ratio = fuel flow ratio ^2 = 3.0044 say your stock fuel pressure is 15psi. new fuel pressure = 15*3.0044 @ 8psi of boost = 45psi fuel @ 8psi boost FMU rate = (high pressure - base pressure ) / boost pressure FMU rate = (45psi - 15psi) / 8psi = 3.75:1 FMU The max pressure you want to reliably pump through your injectors is 85psi Domestics run low psi fuel injections (8-20psi sometimes) so FMU's are great for them becuase you can double your fuel flow going from 20 to 80psi ... but on an import where you already start at ~43psi of fuel pressure at atmoshpere... then you're limited to adding 45% fuel flow with an FMU Setup (or a dry nitrous setup because it works on the same fuel pressure rise concept)... so with a 12:1 FMU you are limited to 4-5psi while still being considered 'safe' so that's what i was saying... @ 8psi , with a 12:1 FMU you run some 124psi fuel pressure base is ~45psi pressure ratio = 2.75 flow ratio = 1.65 =+65% from your injectors stock injector = 200? cc new injector = 330cc/min flow ratio = 330/200 = 1.65 = +65% so at idle , the FMU isn't active...so you only have the increased fuel from the injector upgrade which is the 50-65% i quoted you at idle... under boost you have to multiply the flow rates new flow rate = 1.65*1.65*stock = 2.72 * stock so 200 * 2.72 = 540cc/min injectors 540cc/min /1.5 = 363 wheel hp worth of fuel if you're actually making 250 hp instead of 363 then your a/f ratio should be around 250/363* (12:1) = 8.3:1 << rich -nuke -------------------- 2005 MB C200 Kompressor- K&N, Apexi WS2 Catback, DIY Voltage stabilizer, Intrax Springs, H&R RR swaybar, VDO Boost Gauge @ 6psi, Greddy L7 plugs, +0 Rear tires
thanks nuke this is a big help
QUOTE keep it coming biggrin.gif can't... i'm all out of info on this topic This post has been edited by NuclearHappineS: Apr 12, 2006 - 6:03 PM -------------------- 2005 MB C200 Kompressor- K&N, Apexi WS2 Catback, DIY Voltage stabilizer, Intrax Springs, H&R RR swaybar, VDO Boost Gauge @ 6psi, Greddy L7 plugs, +0 Rear tires
Enthusiast Joined Apr 13, '06 Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(NuclearHappineS @ Apr 12, 2006 - 6:02 PM) [snapback]420762[/snapback] QUOTE keep it coming biggrin.gif can't... i'm all out of info on this topic I have a very similar problem. I`m running probe injectors, 255 fuel pump, and a safc2. I`ve got it turned down -50 and it still idles at around 11 to 1. Useing a AEM wideband guage. Am i missing something? What can i do to get this thing to lean out some? Also have check valve and stock preasure regulator, could that be the problem? |
QUOTE Also have check valve and stock preasure regulator, could that be the problem? yes. -------------------- Former Team 5SFTE pro member ;)
[quote name='presure2' date='Apr 13, 2006 - 1:04 PM' post='421091']
[quote]Also have check valve and stock preasure regulator, could that be the problem?[/quote] yes. [/quote What would more than likely be the main problem the regulator or not haveing a 2 bar map. Are just both |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) ![]() |
QUOTE(trd94 @ Apr 11, 2006 - 12:45 AM) [snapback]420095[/snapback] ok i just intalled my new turbo kit and it seems to be running a little rich , my kit includes , t3 turbo in a 60 trim , wastegated at 7 psi , 89 ford probe injectors, 3 in intake pipe& down pipe back is also 3 in, 12:1 fmu , walbros 255 fuel pump, type rs bov,and a costome mount side intercooler, i have all the other little thing for the kit as well, i retarded my timming by 6 degrees and it just wont smooth out ![]() ![]() the timing i retarded on the dyno also do you have one step colder plugs? -------------------- yea your 3sgte is cool but ill stick to my 7agte
Lo-Fi Version | Time is now: February 23rd, 2025 - 5:20 AM |
