Rough sounding engine noise |
Apr 11, 2006 - 4:53 PM |
Enthusiast Joined Mar 26, '05 From Snohomish, WA. Currently Offline Reputation: 0 (0%) |
My engine makes a wierd knocking noise whenever i go over 3000 rpm. I think it's just a bearing but i dont know how to fix it, and i really hope its not a rod because then im really SOL. Thanks for your help.
-------------------- You only live once...
Apr 12, 2006 - 12:53 AM |
Enthusiast Joined Mar 19, '06 From augusta ga Currently Offline Reputation: 0 (0%) |
i have a 94 st that makes a knocking sound when i go over 3k too.
my check engine light is on and the code i got says the egr system but i don't know if they are related. also if i am outside and reving it up from under the hood it makes the noise and it sounds like it coming from up top i am going to try to figure it out though and like you hope it's not a rod. i'll let you know how minwe turns out. -------------------- 94 st
Apr 12, 2006 - 11:27 AM |
Enthusiast Joined Sep 29, '05 From Rochester, Massachusetts Currently Offline Reputation: 2 (100%) |
Did you check your timing?
-------------------- The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed? |
Apr 12, 2006 - 5:12 PM |
QUOTE(morbiddelusions @ Apr 11, 2006 - 10:53 PM) [snapback]420524[/snapback] i have a 94 st that makes a knocking sound when i go over 3k too. my check engine light is on and the code i got says the egr system but i don't know if they are related. also if i am outside and reving it up from under the hood it makes the noise and it sounds like it coming from up top i am going to try to figure it out though and like you hope it's not a rod. i'll let you know how minwe turns out. Yeah i am really hopeing that it's not a rod. I would like to know how to yours turns out. Thanks QUOTE(nightryder @ Apr 12, 2006 - 9:27 AM) [snapback]420642[/snapback] Did you check your timing? I don't think it has to do with timing, but im not sure so i'll check it out just in case... Thanks for your advice! -------------------- You only live once...
Apr 14, 2006 - 8:49 AM |
Enthusiast Joined Jul 23, '03 From USA Currently Offline Reputation: 0 (0%) |
Sound like from wheel bearing... I have same problem when engine over 3k rpm even the car on idle (car is not running) or while driving, you can hear the noise around the axel. I am going to change wheel bearing in a month, but I have to find out how difficult to make a change.
Apr 14, 2006 - 9:04 AM |
a sound like a wheel bearing that comes from the engine when parked with the engine running could be a bad belt tensioner. one of my dads old fords did that, it eventually turned into a squeel.
see if you can narrow down where the noise is coming from in the engine bay. -------------------- |
Apr 14, 2006 - 3:28 PM |
QUOTE(Bitter @ Apr 14, 2006 - 7:04 AM) [snapback]421473[/snapback] a sound like a wheel bearing that comes from the engine when parked with the engine running could be a bad belt tensioner. one of my dads old fords did that, it eventually turned into a squeel. see if you can narrow down where the noise is coming from in the engine bay. I'm starting to hear a squeel kinda too now... But mine knocking noise is ony when i first turn it on (it knocks exactly 3 times) and when i go over (or come close to) 3000 rpm. And when it happened and i freaked and checked the engine, my oil was bone dry. I've sence discovered that my older car burns a little oil and i've never made that mistake again. -------------------- You only live once...
Apr 14, 2006 - 4:44 PM |
Enthusiast Joined Apr 22, '04 From illinois Currently Offline Reputation: 0 (0%) |
Take a long screw driver and put the blade end agianst the engine and the end of the handle onto your ear. This way, you can listen to where the knock is coming from. Check the head, then find a way to check the block. Believe it or not, if it's a rod bearing, you can actually narrow it down to 1, 2, 3, or 4th cyl. with this trick. That way, you know what you need to order. If it is a rod bearing, all you have to do is drain the oil, take everything off you need to take off to be able to take the oil pan off, take the oil pan off, put a socket and extension on each rod cap and give them a push frontwards (toward the front of the car) and backwards. If they move, you defiantly know that is a bad bearing. If none of them move, then start taking the caps off one by one, (make sure you DO NOT mix them up). The way you know if you have a bad bearing is if it is charred (which would be a spun bearing, and if it is spun, consider your self lucky that it didn't weld to the crank), or if you can see a lot of copper on the half of the bearing you have in your hand (after taking it out of the rod cap). When you reassemble, coat the inside (the part that will touch the crank) with assembly lube and find out what the right tourqe specifications are (you will have to use an inch-pound tourqe wrench).
Have a good one and good luck. -Spunky393 -------------------- The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
Apr 15, 2006 - 3:53 PM |
i found out today that its a rod thats making the noise and that it's cheaper to just do an engine swap than to try and rebuild the engine.
Darn! What should i do? This post has been edited by needforspeed: Apr 15, 2006 - 4:18 PM -------------------- You only live once...
Lo-Fi Version | Time is now: November 24th, 2024 - 5:53 AM |
