2 Pages V  < 1 2
> Port and Polish
post Nov 15, 2002 - 1:51 AM
JWalk1818
Joined Aug 30, '02
From North Carolina
99 Toyota Tacoma
post Nov 15, 2002 - 11:05 AM
trdcelica99
Joined Oct 21, '02
From florida
i was under the impression that a port and polish was just making your engine back to stock and overhauling it, i thought if you bored it out and possible made it from a 2.2 to a 2.3 or 2.4 then maybe you would see that kind of gain, but 30-40hp from a port and polish? confused.gif
post Nov 15, 2002 - 11:11 AM
JWalk1818
Joined Aug 30, '02
From North Carolina
Thats what it does right it bores it out some and cleans everythign out so the air goes through freeier. Maybe I am mistaken but its kinda liek borign it out right. Im not sure about that either my friend did it to his stang and he lost lots of bottom end!
99 Toyota Tacoma
post Nov 18, 2002 - 1:20 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
I did a P&P on my old 5sfe... ended up blowing the motor... but gave me a reason to buy a 3sgte! P&Ped the 3sgte...different shop... and have had no probs with it sofar.
I noticed quite a bit of gain on the 5sfe but it only lasted about 2 weeks.
The 3sgte didn't have quite the same gain but this was the 1st thing that I did to it and have since noticed that I get really good gains when ever I add anything new to the motor so maybe I haven't reached the full potential of the P&P yet.
post Nov 18, 2002 - 1:25 AM
1bwilson
Joined Aug 30, '02
From Maryland
What did you have on your 5s? Still have anything from it?
-Bryan-
Member of Team 5sfTe
post Nov 18, 2002 - 1:29 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
You are kind of right about the port and polish and the bore. It basically restores lost power, but will put it over stock if done right... and please DON'T bust out a dremel and try this yourself!
As for changing the displacement ex.. 2.2 to a 2.4 this is done by boring and resleveing your cylinder walls. you will aslo need to install new pistions to get the best gains out of this.
Keep in mind that if you are going to turbo your car you need to not go too big in a displacement change.
Also new cams and gears would be a smart thing to do if you are thinking about P&P and/or boring.
Talk to a tech shop before doing anything like this they will be able to suggest which route would be the best for what you want the engine to do when it is done.
post Dec 15, 2002 - 8:01 PM
94gtcelica
Joined Dec 14, '02
From USA, NC
so how much are we talking for the WHOLE setup including all the other stuff you need to see a difference
post Dec 15, 2002 - 8:40 PM
bonzaisushi
Joined Oct 3, '02
From bonzaisushi@hotmail.com
theres a shop around here called kc head... hehehe head biggrin.gif . but ne waz they do that stuff i think a guy got it done to his kia for 400 dollars, they also do head work to and that puts out some significant gains from what ive heard. its pretty kool cuz if u take ur car in to get head work theyll pop another stock head on for you so you dont have to be without a car for 2 weeks just my .02
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 24th, 2024 - 1:28 AM
