> Spark Plugs, What kind is the best?
post Apr 12, 2006 - 9:13 AM
WALKER
Joined Mar 29, '06
From Regina, SK, Canada
I tried doing a search for what spark plugs people have used and have had good success with in their cars. Please let me know what type of spark plugs you are using and if they are good or bad and what experiences you have had with them if any. Also if you wouldn't mind saying what type of engine you have it installed on. Right now I have the 5SFE engine but am eventually wanting to go to a 3SGTE, any need to have different plugs for the two engine types?
post Apr 12, 2006 - 9:16 AM
stock denso or ngk plugs are your best bet for the 5s/3s (at stock boost levels)/ 7a
when you up the boost on the 3s, most guys go with a 1 step colder plug.
post Apr 12, 2006 - 9:37 AM
4wheelWOnder
Joined Jan 1, '05
From rapid city, SD
ngk iridiums did my 3sfe well
post Apr 12, 2006 - 12:01 PM
WALKER
Joined Mar 29, '06
Can you order the NGK's pregapped? What is the proper gap for the spark plugs?
Just looked on the NGK catalogue and it has the gap defined as 0.044, part number BKR6EIX-11 (Iridium IX). Does that gap sound correct?
post Apr 12, 2006 - 12:03 PM
SPARK PLUG
application.................NGK #....................Denso #
1.8L (7A-FE) ........... BKR5EYA ................ K16R-U
2.2L (5S-FE) .......... BKR6EP11 ............... PK20R11
4-CYLINDER SPARK PLUG SPECIFICATIONS
application.................GAp#in.(mm)........Tq in FT/lb(n.m.)#
1.8L (7A-FE) ......... .031 (0.79) ............. 13 (18)
2.2L (5S-FE) ......... .043 (1.09) ............. 13 (18)
toyota BGB
This post has been edited by playr158: Apr 12, 2006 - 12:04 PM
post Apr 12, 2006 - 1:58 PM
spunky393
Joined Apr 22, '04
From illinois
i have very good luck with boush platinum +4's. Other than the CAI, my engine is stock
The most important lesson I learned from Karate-Dô Kyôshan“You can not be what you do not believe you are”
post Apr 12, 2006 - 2:31 PM
WALKER
Joined Mar 29, '06
Playr - Thanks for your post, you also answered my next question about the proper torque to tighten them with.
post Apr 13, 2006 - 4:21 PM
immortal
Joined Aug 21, '05
From Cyprus
for the beams engine what do you suggest guys?
post Apr 13, 2006 - 4:34 PM
Yellow94GT
Joined Mar 17, '06
QUOTE(WALKER @ Apr 12, 2006 - 3:31 PM) [snapback]420702[/snapback]
post Apr 16, 2006 - 7:58 PM
nightryder
Joined Sep 29, '05
From Rochester, Massachusetts
i would have to agree with spunky, my bosch platinum +4's have treated me pretty well
The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed?
post Apr 17, 2006 - 2:59 PM
desertwolf300
Joined Sep 27, '04
From Texas
I agree, Bosch +4's are doing well for me, too. I've had them in my car for almost 1.5 years and checked them for fouling three weeks ago. They were unbelievably clean and I still get good response and gas milage.
- Bill
post Apr 18, 2006 - 10:39 AM
Negative
Joined Apr 28, '04
From Houston, Texas
So far I have not found anything better than the NGK Irridiums. Denso (stock plugs, wires etc) and NGK are the same company so going with stock and the upgrade in metals seems to make the most sense to me.
I had the Bosch Platinum +4's on my old 3s-GTE swapped 4th gen but a mechanic told me they were causing problems with my pistons (I think he said they were burning the tops of the pistons or something).
post Apr 18, 2006 - 10:43 PM
FreddyTheOthaMea...
Joined Feb 8, '04
From Thornton, CO.
Bosch* +4s are engineered for euro cars, why would you put em into a jap import?? I have NGK irridiums in mine, runs pretty good.
Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..."
post Apr 19, 2006 - 12:09 AM
C3L1CA
Joined Mar 11, '04
From Oakdale, MN
Not trying to hijack but I have a question
Alright I plan on running between a 35 and 50 shot of nitrous for a little fun this summer and wanted to do things as safely as possible. I've read up and people have been saying that NGK plugs are good for nitrous from my understanding and that you're supposed to run a step or two colder so the spark doesn't blow. Can somebody help me find what plug I should get or point me in the right direction. I know I’m a noob but want to do it as safely as possible.
-Brad
01 a4: daily
post Apr 19, 2006 - 7:01 AM
then 1 step colder you want
BKR7E
2 steps
BKR8E
post Apr 19, 2006 - 8:20 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Spark plugs are just a matter of psychology matters: this works better, that one works better, this has iridium tips and that one has platnium tips.
Either way you look at it, its all taste and preference and for a 7afe engine I would just stick to the cheap $1-2 spark plugs, cause it wont do you any better to run Irdium Plugs that cost $5-8.
Spark plugs do not make you gain any more HP than wat came stock on your engine, unless of course you didn't gap it right, it does lag like crap.
Unless u have a high performance engine, tick with cheapo!
post Apr 19, 2006 - 8:27 AM
QUOTE(soulshadow @ Apr 19, 2006 - 9:20 AM) [snapback]423437[/snapback]
this is kinda of a dumb statement....
the heat range on which you're selecting has an effect on what your motor runs like as well as a proper gap...
iridiums will work well on a naturally aspirated car but on a forced feed car...now thats a different story
i think import tuner or someone came out with a rather large spread on spark plug information...
but its not "psychology" there is a proper way to do spark plugs...
http://www.ngksparkplugs.com/techinfo/spar...=31000&country=
This post has been edited by playr158: Apr 19, 2006 - 8:30 AM
post Apr 19, 2006 - 8:30 AM
Negative
Joined Apr 28, '04
From Houston, Texas
Agreed.
post Apr 19, 2006 - 8:34 AM
C3L1CA
Joined Mar 11, '04
From Oakdale, MN
QUOTE(playr158 @ Apr 19, 2006 - 7:01 AM) [snapback]423416[/snapback]
BKR7E
2 steps
BKR8E
-Brad
01 a4: daily
post Apr 19, 2006 - 2:22 PM
WALKER
Joined Mar 29, '06
One more question that I am going to throw out there in regards to the 1 step colder plug (ie. BKR7E vs. BKR6E). It was mentioned that when going with the 3S engine some go one step colder, also now been brought up with regards to nitrous application.
Is there a negative side to going with a BKR6E on a 5S engine? Not that I am planning on doing that, just curious to find out what possible problems (if any) you could run into if you went with 1 or 2 steps colder than recommended.
Lo-Fi Version Time is now: February 17th, 2025 - 5:13 AM
