> Valve cover
post Apr 13, 2006 - 7:14 AM
TrdPnoy
Joined Sep 6, '04
From Canada
Hey guys I was just wondering what size socket do I use to remove the 5sfe valve cover thanks.
post Apr 13, 2006 - 7:26 AM
IIRC its 30mm.
youll also need to remove the throttle cable bracket, (2X 14mm) and the 2 10mm bolts holding the wire harness covering the LH side of the valve cover.
post Apr 13, 2006 - 7:38 AM
TrdPnoy
Joined Sep 6, '04
From Canada
Thanks bro
post Apr 13, 2006 - 1:48 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
i just did this on chanhs old engine, theres 1 10mm bolt on the right top...then remove plug wires. i used a cresent wrench since i didnt have a 30mm socket for the top 4 bolts and pried the other pieces under that and it comes off, i didnt have to remove the 2 left side ones.
post Apr 13, 2006 - 8:33 PM
Valo666
Joined May 15, '05
From Toronto
bing..u wanna paint ur cover??..ive got one in my garage duin nothin if u wanna clean it up and paint it. talk 2 me on msn and lemme know if ur interested.
post Apr 14, 2006 - 12:32 AM
blu94gt
Joined Mar 23, '05
From Kansas City
QUOTE(LewFX @ Apr 13, 2006 - 1:48 PM) [snapback]421114[/snapback]
10mm bolt? I don't think that does anything, mine doesn't even have that. I just did my valve cover gasket, all I had to remove was the 4 30mm nuts from the spark plug tubes. (just FYI 30mm is the same as 1 and 3/16 inches if that's all you can find, I got that socket for 2 bucks from a tool store haha)
1999 Celica GT
Lo-Fi Version Time is now: February 25th, 2025 - 2:33 PM
