3 Pages V   1 2 3 >
> turbo vs. super, please input!
turbocharger VS supercharger
Total Votes: 69
Guests cannot vote
post Apr 13, 2006 - 10:15 AM
m0dd3d1
Joined Jan 30, '06
From Augusta, GA
so what kind of power and torque differences can i expect with a supercharger instead of a turbo with my 98 gt? any input is very appreciative!
1998 Toyota Celica GT
2007 Subaru Impreza WRX STi
2007 Toyota Tacoma 4x4
1974 Datsun 260Z
1997 Subaru Legacy L Wagon
post Apr 13, 2006 - 4:11 PM
yungazzdriver
Joined Feb 15, '05
From Frederick, Maryland
the only thing you can expect is to keep spinning off the line with a supercharger
post Apr 13, 2006 - 4:16 PM
Cutrara
Joined May 6, '05
From PA
Superchargers are better cause there's virtually no lag, but the only kit made for the 5S is rare. A good option for an ST driver would be a 4A-GZE swap.
post Apr 14, 2006 - 12:30 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
post Apr 14, 2006 - 12:57 AM
burneeed
Joined Dec 18, '05
From BANNED
blower for our cars = dumb
BANNED!
post Apr 14, 2006 - 1:24 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
QUOTE(burneeed @ Apr 14, 2006 - 5:57 AM) [snapback]421405[/snapback]
explain please
post Apr 14, 2006 - 1:37 AM
tomazws
Joined Oct 30, '04
From So Cal
somewhere i read said supercharger eats power.... either from the alternator or from battery.. I forgot... anyway just ignore me .... i donno what i'm talking about lol
post Apr 14, 2006 - 2:00 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
A turbocharger will give you lag
A supercharger will will take away some torque
**** Photobucket
post Apr 14, 2006 - 2:27 AM
Hanyo
Joined Aug 16, '03
From Bay area
i prefer supercharger over turbo for our cars because of the characterists of our engines. Our engine have alot of torque in the midrange and very little on the high end.
But pound for pound of boost a turbo will make more power. Lets say we have a 5sfe running on 5 psi of boost. a supercharge 5sfe will only make 150 hp, where as a turbocharged 5sfe will make 160.
I voted supercharge because I prefer to have a constant predictable powerband.
post Apr 14, 2006 - 4:28 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE(Hanyo @ Apr 14, 2006 - 12:27 AM) [snapback]421431[/snapback]
that depends on a lot of things, you cant just say any turbo will make more power pound for pound than a supercharger
and a turbo will easily fix the horrible top end that these cars have.
turbo is cheaper, and easier
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Apr 14, 2006 - 5:46 AM
idk what dyno charts you have seen from the 5sfte, but id like to think that this dyno sheet im posting is pretty constant, and predictable.
i really like the supercharger option, just a shame there is virtually no options left when it comes to them
that said, i vote turbo because of the flexability of the setup.
post Apr 14, 2006 - 7:13 AM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
This could go either way.
Supercharger: Overall approx 85% efficiency, near instantaneous torque depeding on blower style (roots, centrifugal), linear powerband directly related to engine RPM.
Turbo: Overall approx 95% efficiency equating to more power at a given boost point over a blower, more potential than a blower, but non-linear powerband, turbo lag, and more difficult to tune. Also, exponentially more expensive.
post Apr 14, 2006 - 9:33 AM
NuclearHappineS
Joined Oct 17, '04
From St Louis, MO
I owned a custom turboed car, a stock twin turoed car, and a now a supercharged car
reliability : supercharger > turbo
reason: 1 fixed boost level, 1 level to tune at, less complex boost, simpler (or self contained) oiling system, simpler control/fueling systems (no wastegates, boost controllers...etc)
power: turbo > supercharger
reason: variable boost level, racegas+moreboost+more timing option, infinitely adjustable setup (for low end or top end)
Lag is overrated... the VR4 (stock TT) could hit FULL boost @ 2300 rpms ...
Most newer S/C cars are not allowed to boost (although they are capable of making boost) before say 3k (that's how my car is) because that improves fuel effeciency ...
the mazda speed supercharged miata was like that too ... they wanted torque delivery to be linear so boost is regulated at low rpms
here's the thing
what's the point of having a 1000-4000 rpm boost band, when you have a 3000-6500 power band (as determined by your gearing)... superchargers (blowers specifically) can make boost at idle but their effeciency drops with rising CFM, rising supercharger rpm and rising boost)
example: my eaton m45 on the benz 1.8 litre consumes 30HP at redline
The supercharger temps @ redline are 25 degrees higher than they are at low rpms, and it's limited to a 10psi output (effeciently) at those rpms otherwise the temps shoot up even higher..
a properly sized turbo on teh same motor, with a good intercooler , can be at peak effeciency at redline @ 15psi ... i'd gaing 30hp in supercharger drive, the same outlet temps, and 5 more PSI of boost which translates to some 80 hp more than i have now
that's the difference between a 200hp and a 280 hp setup on a 1.8 litre
which one is better now ?
2005 MB C200 Kompressor- K&N, Apexi WS2 Catback, DIY Voltage stabilizer, Intrax Springs, H&R RR swaybar, VDO Boost Gauge @ 6psi, Greddy L7 plugs, +0 Rear tires
To Do: E-manage Ultimate tuned up to 12psi
post Apr 14, 2006 - 2:25 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
i'll tell you have to defeat lag
DOWNSHIFT
just like NuclearHappineS said, no point in having good power at torque at 2500rpm when your gearing keeps up above 3500rpm
lag is only a problem in 1st gear, and to people that are too lazy to downshift when they want to accelerate
oh and superchargering a car is not cheaper than turboing a car
post Apr 14, 2006 - 3:47 PM
team_omega
Joined Aug 14, '05
From St. Paul, MN(USA)
but remember that a supercharger runs on a belt which will give more stress to the engine.
post Apr 14, 2006 - 3:59 PM
lilsteeg
Joined Jan 16, '06
From Lima, ohio
QUOTE(Cutrara @ Apr 13, 2006 - 4:16 PM) [snapback]421158[/snapback]
no, supercharger actually takes power to make it work, a turbo is free power, so you will make more power with a turbo, and with a variable geometry turbo, there is no lag
post Apr 14, 2006 - 5:23 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(team_omega @ Apr 14, 2006 - 1:47 PM) [snapback]421592[/snapback]
Huh? A turbo adds exhaust backpressure and heat.... I'd say that's not great for an engine either
QUOTE(lilsteeg @ Apr 14, 2006 - 1:59 PM) [snapback]421598[/snapback]
Turbos do not make 'free power'... there is generally less airflow through the motor at a given boost pressure because of the increased exhaust backpressure. The parasitic losses of a turbo are hidden from being able to be measured because they are directly related to the amount of power they are creating, instead of engine speed.
There is also no such thing as "no lag" with a turbo. There will always be some... Most of the time, its not really noticable (the boost comes up with the throttle as long as you don't slam on the gas).
Also, I dare you to find a VTN turbo out there that someone could adapt to a 'normal' car at this point. Maybe someday soon (they are already used in new diesels...).
Eh, whatever. My point is, there are no absolutes in the turbocharge/supercharge debate.
Generally though: Reliability/predicability goes to supercharging, power/tunability goes to turbocharging.
I have personally gone with turbos on all my cars because I like to tinker. If I wanted a 'set and forget' thing for 30-60k miles+, I'd try to find a supercharger option...
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Apr 15, 2006 - 3:33 AM
NuclearHappineS
Joined Oct 17, '04
From St Louis, MO
+1 on that opinion... but like i said ...ultimate power sattisfaction imho is either turbo or centrifugal supercharger (which is still really a turbo)...
post Apr 15, 2006 - 2:41 PM
burneeed
Joined Dec 18, '05
From BANNED
yes blowers are dumb for our cars. Theres really no reason if you want boost to go supercharger. Depending on what you expect to get power wise, 5sfte turbo is good for around 200hp unless your manny heh biggrin.gif. Im still amazed to see what kind of power that guy puts out of his 5s motor. Getting back to the blower, After going through a 5sfte turbo setup in my 5th gen and now having a 3sgte in my 6th gen ... 3s is the way to go. Theres so much potential with that motor. Looking at what most of the mr2 guys do with 3s motors its unreal to see the kind of power they put out. You put that blower on there maybe do a little bit of bolt ons and your done. Theres really not too much aftermarket support for our cars with blowers. I know rip made a kid for a camry which should work with a 5s motor. Other than that I dont really see you getting far with a blower. Supercharger migh just be a little more reliable than a turbo but turbo always puts out more power and theres alot more tuning with a turbo. Just over all how it works, with the crank oposed to exhaust gas. Blowers are good for big domestic v8s but little 4 bangers...... not a good idea.
BANNED!
post Apr 15, 2006 - 2:59 PM
pandakid
Joined Feb 12, '06
From Fresno CA
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: November 23rd, 2024 - 11:46 AM
