> 2 BAR MAP
post Apr 16, 2006 - 12:46 PM
NateG
Joined Apr 13, '06
Ive read that you can use a 3sgte map sensor on a 7afte. Where can i get one? Haveing trouble finding. Anybody used the gm 2 bar map. If so how good does it work, any better than 3sgte?
post Apr 16, 2006 - 4:58 PM
trd94
Joined Jan 9, '05
From green springs ohio
post Apr 16, 2006 - 7:16 PM
you can get the 2 bar map from alltrac.net and mr2oc.com
or ebay
90-93 alltrac
90+ mr2T
post Apr 17, 2006 - 12:28 AM
dans_st
Joined May 24, '03
From Andrews TX
I have gm 3bar, plan to switch to 2bar
If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
post Apr 17, 2006 - 7:24 AM
NateG
Joined Apr 13, '06
Do you have a part number?
post Apr 17, 2006 - 11:44 PM
dans_st
Joined May 24, '03
From Andrews TX
MAP 1 Bar Sensor, for normally aspirated applications
Part # 30-7007
MAP 2 Bar Sensor, for turbo applications up to 20 psi boost
Part # 30-7008
MAP 3 Bar Sensor, for turbo applications up to 30 psi boost
Part # 30-7009
MAP 5 Bar Sensor, for turbo applications up to 60 psi boost
Part # 30-7056
as for the harness you can usually get one at a junk yard for a couple bucks
hope this helps
-Daniel
Lo-Fi Version Time is now: February 22nd, 2025 - 12:52 PM
