3sgte question |
3sgte question |
Apr 19, 2006 - 3:19 AM |
Enthusiast Joined Jan 1, '05 From rapid city, SD Currently Offline Reputation: 0 (0%) |
Does anyone know if you can use a awd 3sgte transmission, with a 3rd gen 3sge???
Apr 19, 2006 - 5:26 AM |
not in a FWD celica, without serious modification.
well, actually, it WILL fit....but you'd be loosing 50% of the power thru the transfer case. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Apr 19, 2006 - 9:02 AM |
Enthusiast Joined Feb 15, '05 From Frederick, Maryland Currently Offline Reputation: 8 (75%) |
you actually could use it and make it work, i actually have a working awd transmission but you must correctly convert it to fwd and it is well explained at celicatech.com i will be using the awd tranny converted to fwd using the mr2 tranny transfer case cover and,..........a cusco lsd using the alltrac axles.
Apr 19, 2006 - 9:15 AM |
well i plan on using the awd tranny along with the drivetrain.....i am going to do an awd conversion in short, but that is why i was asking.....anywho. as far as mating it to the 3sge engine there shouldnt be a problem ..........right?
Apr 19, 2006 - 1:40 PM |
Enthusiast Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
QUOTE(4wheelWOnder @ Apr 19, 2006 - 7:15 AM) [snapback]423465[/snapback] well i plan on using the awd tranny along with the drivetrain.....i am going to do an awd conversion in short, but that is why i was asking.....anywho. as far as mating it to the 3sge engine there shouldnt be a problem ..........right? Mounting the motor to the tranny is no problem. Mounting the AWD parts is a problem - the floor pan it completely different and there are no mounts for the AWD parts in your Celica. -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Lo-Fi Version | Time is now: November 23rd, 2024 - 12:56 PM |
