> Swapped celica won't start, 3sgte into a 92 celica
post Apr 19, 2006 - 11:58 AM
3sgte@daspeedof
Joined May 23, '05
From Sauga
I thought it was my starter, so I swapped it out. I took in my battery and it wasn't holding a charge so I got a new one and it still won't start. What else would cause this? what specific sensors am I looking at?
post Apr 19, 2006 - 1:59 PM
phattyduck
Joined Dec 5, '05
From LA, CA
We need more info... do you hear the starter clicking? have you checked all your plugs? is the motor turning over at all? Have you checked your fuses?
etc...
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Apr 19, 2006 - 2:31 PM
3sgte@daspeedof
Joined May 23, '05
From Sauga
I haven't checked my fueses gonna check those, and my coil & ignitor, don't know what else it could be
post Apr 19, 2006 - 2:57 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
I checked your other thread here:
http://www.celicatech.com/forums/showthrea...1175#post181175
Now that we know it's cranking, can you tell us if you have spark or fuel? Have you checked the trouble codes? If you have both spark and fuel and no codes you'll want to check timing next.
post Apr 21, 2006 - 12:12 PM
3sgte@daspeedof
Joined May 23, '05
From Sauga
I found out that my efi fuse was blown, hence the reason it wouldn't start, duh!!
I know I overlooked the little thing of just checking my fuses. But when I ran my cel codes it came back with two cel errors. 24 & 32, would they cause me to only be reading 6psi on my boost gauge? And what else would cause this?
Now today, Its only hitting 5psi
post Apr 21, 2006 - 12:22 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
24 - AIR Open or short circuit in Air Temp Sensor Check Air Temp Sensor
32 - AFM Open circuit or short in E2 signal Test or replace Air flow Meter
so everyone doesnt have to search
post Apr 22, 2006 - 1:32 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
I thought code 31 was for AFM short or open.
post Apr 22, 2006 - 11:13 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(MaskedMan @ Apr 22, 2006 - 1:32 AM) [snapback]424708[/snapback]
post Apr 22, 2006 - 11:23 AM
3sgte@daspeedof
Joined May 23, '05
From Sauga
yea I read it, I'm hoping its not my afm but thats what things are leaning towards, without me checking the voltage I won't know for sure though
Lo-Fi Version Time is now: February 23rd, 2025 - 7:00 AM
