Enthusiast ![]() Joined Dec 28, '05 From Norway Currently Offline Reputation: 0 (0%) ![]() |
So, i warped my new original rotors using my new original pads. I was wondering if I should replace the pads too now that i'm replacing the discs. The pads is about 9 months old. If I replace the pads, I think I would go with EBC greenstuff. Are those good pads?
Thanks ![]() -------------------- ![]() |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 25, '05 From Fort Wayne, IN Currently Offline Reputation: 14 (100%) ![]() |
QUOTE(eliaz @ Apr 19, 2006 - 1:20 PM) [snapback]423537[/snapback] So, i warped my new original rotors using my new original pads. I was wondering if I should replace the pads too now that i'm replacing the discs. The pads is about 9 months old. If I replace the pads, I think I would go with EBC greenstuff. Are those good pads? Thanks ![]() Yes. It goes either way. If you replace one, replace the other (unless you're replacing the pads and the rotor is good, simply have the rotor turned). Reason being is that the pad and rotor develop a wear pattern to each other and actually groove. If you replace one and not the other, you get an uneven wear pattern that will lead to poor heat distribution across the pad/rotor area, and eventually, warping. -------------------- |
Thanks for the good info mate
EBC greenstuff a+
I hear they wear quick?
they do, and they eat rotors as well. i recomend hawk hps pads.
wear quick...haha thats a joke
i've had mine on for a very long time..little signs of wear and i was hard on them esp with drilled and slotted rotors... i think i was well near 10,000 miles or more on my ebc green stuffs and they still had a TON of life left.. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) ![]() |
what about ceramic pads?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) ![]() |
a good rule of thumb when cutting, trimming or replacing rotors is to get some new pads, you dont want to glaze the old pads or have glazed pads resurface the newer rotors and warp them again.
How about redstuff?
This post has been edited by eliaz: Apr 23, 2006 - 7:35 AM -------------------- ![]() |
those arn't street pads really...and you won't get them warm enough
Lo-Fi Version | Time is now: February 22nd, 2025 - 4:45 AM |
