![]() Enthusiast ![]() ![]() ![]() Joined Feb 8, '04 From Thornton, CO. Currently Offline Reputation: 1 (100%) ![]() |
I'll post pics in a bit (as i just managed to drag myself out of bed), but heres what I got...
1: Optima Yellow top batt 2: Kenwood KDC-X790 head unit 3: Infinity Reference Component speakers (Both for front and rear) 4: Infinity Reference 10 subwoofer w/ Custom made box 5: Kenwood 500rms watt amp I'll probably upgrade the wiring (power and ground) to either 2g-0g, as I'm at a 4g right now and bust fuses anytime i crank the amp up (at the output source). Its pretty loud but primarily clear as hell. comments/suggestions are welcomed and again i'll post pics in a bit here. -------------------- Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..." ![]() |
![]() Enthusiast ![]() ![]() Joined Jan 21, '05 From NY Currently Offline Reputation: 0 (0%) ![]() |
Pretty good setup. I see no reason for you blowing fuses, right now u have 4ga so thats about 60A of draw from ur alternator. If u go 2 or 0ga u will be able to draw anywhere from 80 to 125A which is good if you have an aftermarket alternator, but if u dont your alternator might die pretty fast if u like to play constant bass.
By the way I had Kenwood 500Watt at 4ohms to 1ch amp in my celi about 5 month ago and it never blew any fuses, and I was running 5ga wire. So I am pretty sure that there is something wrong with your wiring. Right now I am running JBL B1200.1 amp which is rated at 1200watt RMS at 2ohm's (I dont get all 1200watts because of my 5ga limitation) but I do get everything my 5ga can give me and I never blew any fuses. -------------------- <<AKA THA RUSSIAN>>
:nod: im thinking of going over all the wiring inside the box to make sure its all still solidly connected. possibly redo the ground connection.
Lo-Fi Version | Time is now: February 23rd, 2025 - 7:33 AM |
