Lightweight Flywheels!? |
Apr 24, 2006 - 5:09 PM |
Enthusiast Joined Mar 28, '04 From St.Louis Currently Offline Reputation: 15 (100%) |
Ok, well i recently ordered a 9 lb. flywheel from Competition Clutch, best service ever, great price, well i got the flywheel and i matched everything up, teeth for started, pressure plate pins, everything was perfect. Except for the mounting holes to the crankshaft. The flywheel i got had 8 holes, while my crank only has 6 holes. Now obviously that will not work. The engine is a 94 7-afe. I was wondering first of all if anyone has ever found a performance flywheel that will fit and bolt up to this specific engine? and second, what are the differences between the 94 7-afe and the 95-98 engines? except for the obviouse power differences. is the crankshaft on the newer engine an 8 bolt? sorry if this has been posted before, but i have not found any info when i searched.
Thanks for your help. Matt This post has been edited by 94celicadude: Apr 24, 2006 - 5:09 PM -------------------- 1994 GT Hatchback 1994 ST Coupe 1988 Corolla Wagon All-Trac 1999 Corvette 2008 Cobalt SS Turbo |
Apr 24, 2006 - 5:27 PM |
QUOTE(94celicadude @ Apr 24, 2006 - 10:09 PM) [snapback]425845[/snapback] Ok, well i recently ordered a 9 lb. flywheel from Competition Clutch, best service ever, great price, well i got the flywheel and i matched everything up, teeth for started, pressure plate pins, everything was perfect. Except for the mounting holes to the crankshaft. The flywheel i got had 8 holes, while my crank only has 6 holes. Now obviously that will not work. The engine is a 94 7-afe. I was wondering first of all if anyone has ever found a performance flywheel that will fit and bolt up to this specific engine? and second, what are the differences between the 94 7-afe and the 95-98 engines? except for the obviouse power differences. is the crankshaft on the newer engine an 8 bolt? sorry if this has been posted before, but i have not found any info when i searched. Thanks for your help. Matt You got a 4AGE flywheel. There aren't many differences between the early 94-95 7AFE's and the later 96+ 7AFE's... all mechanically the same. The later model 4AGE flywheel (212mm version) is exactly the same as the 7AFE flywheel except it is drilled for an 8 bolt crank. Get a refund... or exchange and make sure it's for the 7AFE with 6 bolts... -------------------- "It's ok to be naked girl... I'm an artist!"
Apr 24, 2006 - 7:05 PM |
well, i am getting a refund. Where can i get a 7afe 6 bolt flywheel? Anybody have one installed on their car?
Lo-Fi Version | Time is now: November 23rd, 2024 - 10:21 AM |
