> Burn Out problem!
post Apr 25, 2006 - 1:57 PM
recycle
Joined Jul 12, '03
From centre of universe, nicosia, cyprus
i tryied some burnouts.... poor $300 tyres...frown.gif...
the problem is that the left wheel spins more than the right one.... and i leave a big black 40metres line on the left and a gray 5 metres line on the right.
whats the problem?
IPB ImageIPB ImageIPB ImageIPB ImageIPB ImageIPB Image
post Apr 25, 2006 - 2:02 PM
hellsyphon
Joined Dec 3, '04
From torrance, ca
I assume your tranny doesnt have LSD. Without LSD to transfer power to the other wheel we have in essence 1 wheel drive. So when your launching or trying to burn out, all of the power you have is being put down on one wheel, which is why your left is spinning or hopping.
post Apr 25, 2006 - 2:10 PM
recycle
Joined Jul 12, '03
it's spinning very good thank u:P that is what i hear but needed a 2nd opinion.
Thanx
post Apr 25, 2006 - 2:45 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
I awlays thought it had something to do with axles
- Ryan
aim: rkgreen04
post Apr 25, 2006 - 4:50 PM
tomazws
Joined Oct 30, '04
From So Cal
QUOTE(hellsyphon @ Apr 25, 2006 - 7:02 PM) [snapback]426300[/snapback]
are u saying our car is not only FWD, but a FLWD?
post Apr 25, 2006 - 4:52 PM
it is like that with any car without LSD, usually the shorter axle (with us the L) is the one that spins wink.gif
post Apr 25, 2006 - 4:57 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Try doing the burnout in second gear. Pull the E-brake, then release it when you want to move foward.
I will return one day.
post Apr 26, 2006 - 5:56 AM
recycle
Joined Jul 12, '03
QUOTE(defgeph @ Apr 26, 2006 - 12:57 AM) [snapback]426372[/snapback]
if only i could post the videos i a format that u guys can see it.... 1st or 2nd gear with me pulling the ebrake up with all my power and car going..!
post Apr 26, 2006 - 7:13 AM
yungazzdriver
Joined Feb 15, '05
From Frederick, Maryland
its like that with all cars w/out lsd, indeed in the launch we have a flwd, what you need is a lsd which can be found off of a beams 6th gen celica motor, i believe its a viscous lsd
post Apr 26, 2006 - 12:39 PM
tomazws
Joined Oct 30, '04
From So Cal
learn something new everyday...
post Apr 27, 2006 - 6:34 PM
TRD-ST204
Joined Sep 26, '04
From Sacramento, California
This phenomenon is called torque steer, and it is common among cars with unequal length drive shafts. Basically when you have a vehicle with unequal length drive shafts it tends to pull to one side. Since our cars have unequal length drive shafts this applies to us.
post Apr 27, 2006 - 10:34 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
i thought torque steer is when you shift agressively and the steering wheel jumps to one side a little bit
post Apr 27, 2006 - 10:45 PM
it occurs during starts, shifts and depends on how much power you have
but like TRDST204 said its cause of unequal length drive shafts and the shorter one getting the greater power..thus pulling to the left on most occasions....basically...learn to hold you wheel really straight and/or get lsd
you'll see it more on launches then anywhere else
This post has been edited by playr158: Apr 27, 2006 - 10:45 PM
post Apr 28, 2006 - 11:55 AM
yungazzdriver
Joined Feb 15, '05
i have the same to say as all above^^^ look its easy to check and see if its lsd or not, jack up front end and turn one wheel forward, youll notice that the other wheel spins the opposite way, but on a lsd'ed tranny, it will go the same way you turn the wheel. ill post up a vid of me turning the tranny i have and you can see
post Apr 28, 2006 - 12:28 PM
^ Thats not an accurate way to tell if you have LSD.
The fact that his tire is spinning more than the other is proof enough theres no LSD, and probably the most accurate way to tell aside from taking apart the tranny.
This post has been edited by Supersprynt: Apr 28, 2006 - 12:29 PM
post Apr 29, 2006 - 8:03 PM
MaX
Joined Nov 7, '05
From Brisbane, Australia
is the beams LSD the only factory one?
post Apr 30, 2006 - 8:15 AM
yungazzdriver
Joined Feb 15, '05
^^^the thing about that is that there are several types of lsd and not all spin the same way.
Lo-Fi Version Time is now: February 22nd, 2025 - 11:52 PM
