![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) ![]() |
Well - non stop hastle..... First of all - i was F'ing tired of searching for SSIII springs.... So i said - what ever..... i just took and bought GT-four springs witch has a bit stiffer spring ratio compared to a SSIII ones (front ones are exactly the same - rear ones has a stiffer ration cuz of the different weight of the car).
Installing a springs on SS suspension was a nightmare compared to a Mac stuff.... After install i found out what one of the joins on the 8 figure is dead and couses the clunking noise.... So this was the last drop for me.... Whats it - im converting to Macferson.... Basicly what i will do - will use the housings of the SStrut Struts cut the damn lower arm what is on the Strut and weld the Mac brackets on to just keep the same shocks and same springs... Now im a bit concerned about few thing - does Subframe where the main arms of superstrut and Mac mounts is the same on both models? and does the Hubs on AT200 and ST202 are the same??? Cuz im a bit woried about the axle having a different slicers and what it will not mount to AT200 hubs (witch are easy to locate here). Well - your thoughts and sugestions are higly welcome - if you have some ideas - let me know. Thanks, Romas -------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) ![]() |
Yeah SS is a real PITA to keep functioning if not well maintained. I dont know if the EU ST and GT hubs are the same. I do know that the struts are a Direct Fit for both. Since my old GT shocks and springs were fitted on a ST with no problems at all.
The only difference is the number of coils the springs have in the front, due to the heavier motor the GT comes equipped with. I think the Subframe was different tho, but i guess the US ST versions are the same subframe wise so if you (or any other 6gc member) can post a picture of the underside of a ST i can compare it. Jacked the car up enough times now to see differences. Edit: Hubs are the same, only difference between GT and ST is brake assembly. Still dont know about the subframe. BTW why dont go to complete McPherson because then you can upgrade the suspension in the future if you want and dont need another custom job to fit it. This post has been edited by Kadett: Apr 27, 2006 - 3:23 PM -------------------- JDM Powerplant installed, BPU coming very soon!
![]() Enthusiast ![]() ![]() ![]() Joined Feb 25, '03 From Springfield, MO Currently Offline Reputation: 1 (100%) ![]() |
go to a salvage yard with a tram gauge or tape measure and measure a MAC style suspension from another celica and compare to yours. if they are the same swap em......not sure if that will help but i can try
-------------------- Coming in 2010 full paintjob - new wheels - modified body - new interior - engine build- marriage |
i got the sub frame covered for ya romas on the at200
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() let me know if you need any other pics/ measurements |
those lower ball joints are at a pretty mena looking angle. i suppose that the car is in the air in all four corners though
Enthusiast ![]() ![]() Joined Apr 20, '06 Currently Offline Reputation: 0 (0%) ![]() |
would it not just be far easier to just replace the worn link.
QUOTE(Edophus @ Apr 28, 2006 - 5:41 PM) [snapback]427717[/snapback] would it not just be far easier to just replace the worn link. Nope. With superstrut suspension prices i could replace WHOLE suspension to Mac for the same price as ONE damn link costs... Dan, thanks for the pics ![]() -------------------- Ex celica owner - just a guy from other side of the pond...
wow how much does the links cost where you are? lol I think your as mad for doing this as you think I am for swapping out my beams
QUOTE(Edophus @ May 2, 2006 - 11:04 AM) [snapback]429093[/snapback] wow how much does the links cost where you are? lol I think your as mad for doing this as you think I am for swapping out my beams ![]() Its about 450 Euros for a 8 figure in front and for the other small link its about 200 euros from toyota... And in Junk yeard i can get WHOLE and i mean WHOLE suspensions from ST for like 200 euros..... so ![]() -------------------- Ex celica owner - just a guy from other side of the pond...
Sorry that i have not replied sooner, been busy. The look alike both like doGGy said from underneath you will get a better picture of the subframe. Tomorrow when I will put on my spacers I will take some photos of my GT suspension+subframe.
This post has been edited by Kadett: May 2, 2006 - 1:37 PM -------------------- JDM Powerplant installed, BPU coming very soon!
Ehm.... Kadett???
Sorry..... so messy with upholding everything I promise.Still no time taken for the spacers so no pics but.............. I can say this
Looking at the pics of Lagos his custom 3" exhaust http://www.6gc.net/forums/index.php?showtopic=36469 The subframe is identical to my GT. So compare it to your setup. -------------------- JDM Powerplant installed, BPU coming very soon!
Lo-Fi Version | Time is now: February 22nd, 2025 - 2:32 PM |
