> fuse location???, Swapers???
post Apr 28, 2006 - 10:10 PM
lantz2121
Joined Jun 27, '04
From ohio
I installed my new fuel pump but when i turn it over the pump is not buzzing or pumping fuel. Is there a fuse designated for the fuel pump? I know the pump works i tested it before I installed it. Any suggestions?
post Apr 28, 2006 - 11:33 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Did you only turn the key one click ? or did you try to start the car ? The pump wont come on until you start the car.
Check the fuses by the steering wheel, then in the engine bay.
I will return one day.
Lo-Fi Version Time is now: November 24th, 2024 - 4:36 AM
