2 Pages V  < 1 2
> 3SGTE, No A/C No Problem
post Apr 3, 2007 - 6:50 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
finally ordered mine today. little over a 100 bucks like Jeff said. biggrin.gif
post Feb 7, 2008 - 12:38 AM
3rdgen3SGTE
Joined Nov 21, '05
From Quebec
I doing like this with jobber belt....
Celica GTS turbo 1994
3sgte genIII Ct20b
post Feb 23, 2009 - 11:23 PM
cibrit-
Joined Sep 16, '08
From Michigan
Omg!! Thank you dep, this is exactly what I was looking for, because my belt is loose and hell, it's set up the same way as the first pic.
I was curious though, is there any place that I can get the pulley tensioner bolt, besides the junkyard? The one that looks like ------|-|-[]
EDIT:
Where did you order the parts from?
This post has been edited by cibrit-: Feb 23, 2009 - 11:27 PM
94' Red Celica ST Hatchback: 3S-GTE Swap
Upgrade??: ATS CT27 Kits
-Toni
post Feb 24, 2009 - 5:07 AM
any toyota dealer can order these parts for you.
post Feb 24, 2009 - 8:57 AM
cibrit-
Joined Sep 16, '08
From Michigan
Alright, thanks!
-Toni
post Feb 24, 2009 - 5:57 PM
cibrit-
Joined Sep 16, '08
From Michigan
QUOTE (defgeph @ Apr 29, 2006 - 6:39 PM) *
Does the bolt come with the pulley? The one that tightens it onto the slot.
EDIT:
Took out double picture
This post has been edited by cibrit-: Feb 24, 2009 - 5:57 PM
-Toni
post Feb 24, 2009 - 5:58 PM
as you can see in jeffs pics, there are 2 parts, 2 part #'s.
the belt, and the pully.
you take your old pully off, install this pully in its place with the old hardware, and install the new belt.
the nut and thru bolt are not included.
post Feb 24, 2009 - 6:05 PM
cibrit-
Joined Sep 16, '08
From Michigan
Well, in the pic I put up the nut and "through bolt" look a lot newer than the first pic he showed of "how not to do it". That's why I was wondering.
-Toni
post Feb 24, 2009 - 8:34 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
i turned up an ally pulley when i removed my air con.
not a hard thing to machine if you can use a lathe.
even with how you had it set up before the belt wouldnt come off, remember the alternator pulley and the harmonic balancer have groves in them so the belt wouldnt slip.
at work we have some belt driven wheels that spin at 9000rpm and more and the pulleys are completly flat and the belt doesnt come off.
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Feb 25, 2009 - 3:15 PM
cibrit-
Joined Sep 16, '08
From Michigan
Sweeet, I just wish I had a lathe at my finger tips tongue.gif.. I know how to use it too.
-Toni
post Feb 25, 2009 - 8:06 PM
cibrit-
Joined Sep 16, '08
From Michigan
How wide is the new belt?
-Toni
post Mar 2, 2009 - 7:54 PM
DEATH
Joined Dec 19, '07
From tx
Jeff you rock - I'm trying to do this and fix a broken alt bolt in the dark at my job right now kindasad.gif
Thanks for the visuals and the how to do it correctly when I get the time/money/light
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Sep 11, 2012 - 3:06 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
I just found a better way, F*ck your expensive pulley biggrin.gif and F*ck the heavy cast iron bracket it sits on smile.gif All you need is that shorter belt.
thats a brass bushing there holding the alternator up to tension the belt, my next step is to machine up a wedge piece with 2 holes to bolt together where the bottom alternator mounting holes now misalign
Mike W
269awhp / 273ft-lbs
post Sep 11, 2012 - 3:10 AM
delusionz
Joined Feb 11, '08
Mike W
269awhp / 273ft-lbs
post Feb 11, 2014 - 2:00 PM
mi645
Joined May 23, '12
From northridge,CA
so Ive researched the part numbers u guys provided it costs 199 usd. for the pulley and about 44 usd for the belt, im an employee of Toyota with my cost its 100 usd for the pulley and 24 for the belt, still outrageously pricey, so I found a 97 4 runner ac pulley, it cost me 20 bucks from an auto store local, and with an oem koyo bearing on it.
post Feb 12, 2014 - 2:56 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (mi645 @ Feb 11, 2014 - 2:00 PM) *
Your discount is the same as the online prices so tongue.gif but yeah, it's still expensive for the pulley.
Can you post what the pulley part number is?
This post has been edited by mkernz22: Feb 12, 2014 - 3:03 PM
post Apr 5, 2014 - 10:22 AM
mkernz22
Joined May 10, '10
From MA
Just some food for thought.
My dad had to order a tensioner pulley for his S/C'd Grand Prix and I feel like it could work on our setup.
The middle is recessed 1/4" on both sides, where as the OEM one is flush.
That's one of the main differences to note.
And there is are 6 groves on this one compared to the 5 on the OEM, but that isn't a big deal.
Here are some pictures of it (with loose measurements).
About 1" wide, 3" in diameter, 5/8" in diameter for the bearing hole.
Since the pulley is about an 1" wide, and the middle is recessed 1/4" on each side, then the bearing is about 1/2" wide.
This post has been edited by mkernz22: Apr 5, 2014 - 10:25 AM
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 29th, 2024 - 7:25 AM
