> boost creep, boost presure drops on hi revs
post Apr 30, 2006 - 11:05 PM
akiyama
Joined Dec 19, '05
what causes boost creeping? im boosting my 7afte at 8psi but when i reach around 5000rpm the boost presure drops to 5 psi. what size exhaust pipe do you use in a 7afte?
post May 1, 2006 - 7:04 PM
trd94
Joined Jan 9, '05
From green springs ohio
QUOTE(akiyama @ Apr 30, 2006 - 11:05 PM) [snapback]428433[/snapback]
i just got my 2 1/2 in done and it gets me to 8.5 psi at 5900 rpm wink.gif
post May 1, 2006 - 7:20 PM
your not refering to the right thing here....
boost CREEP is when for example say your setting is 8psi but you keep boosting and reach 10psi...thats creep
wat you are experiencing is boost DROP...
this is attributed to 3 things i would say
1)your exhaust is too small...
2)your turbo is too small.....your turbo basically doesn't have the efficiency to run at that high of an RPM for the CFM moving and drops
3)your motor doesn't move enough air to keep the turbo spooling fast enough to build that amount of pressure...
exhaust size on a 7afte should be 2.5"
post May 1, 2006 - 11:28 PM
QUOTE(playr158 @ May 1, 2006 - 8:20 PM) [snapback]428777[/snapback]
i just had my car on a dyno and it was at 12-13ish psi and kept droping off to 10psi in the upper rpms.... explain that!
post May 2, 2006 - 12:54 AM
Blakout16
Joined Jul 3, '04
From Yakima, WA
not enough down force, lagos. need a bigger wing. tongue.gif lol im jp.
Lo-Fi Version Time is now: January 10th, 2025 - 12:26 PM
