about timing belt |
about timing belt |
May 1, 2006 - 1:07 AM |
Enthusiast Joined Mar 19, '06 From augusta ga Currently Offline Reputation: 0 (0%) |
Does the timing belt on the 7afe have any slack on either side?
I checked it by removing the cover when i got my celi. The belt didn't look too bad but i don't remember it having any slack in it. I think one of the gears may have jumped place cause i started it up and was backing up and it just shut off. I checked the plugs to insure they were firing and tried some starting fluid. All it would do is turn over and not start so i pulled the cover to see if the belt broke it is still intact but has about an inch or more of slack in it. So is it supposed to have the slack in it? Was just wondering before i rip it apart. -------------------- 94 st
May 1, 2006 - 1:34 AM |
Enthusiast Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
QUOTE(morbiddelusions @ May 1, 2006 - 2:07 AM) [snapback]428471[/snapback] starting fluid. |
May 1, 2006 - 1:48 AM |
Enthusiast Joined Mar 21, '06 From Burnsville, MN Currently Offline Reputation: 0 (0%) |
The belt should only have about 1/4" to 1/2" of play in it. Your starting issue may be a result of the belt jumping a tooth or two because of the loose issue or the belt has stretched out over time and simply needs to be tightened back up. Check to see that the timing is correct by lining up the crank pulley at TDC (the mark on the balancer should be right on zero) and the cam pulley mark is at the 12 o' clock position. Look through the small inspection hole on the cam pulley spoke and you should see an indentation on the 1st exhaust cam bearing cap through the hole. The proper cam bearing mark is the one thats most towards the front of the vehicle (if there are two marks on the cap)
This post has been edited by Speedball-OD: May 1, 2006 - 1:50 AM |
Enthusiast Joined Dec 28, '05 From USA Currently Offline Reputation: 0 (0%) |
not sure if you wanna do it yourself, but i had mine replaced and it cost me about $500
This post has been edited by pure_dx: May 1, 2006 - 1:51 AM |
May 1, 2006 - 11:39 AM |
QUOTE(purplegt4 @ May 1, 2006 - 1:34 AM) [snapback]428475[/snapback] QUOTE(morbiddelusions @ May 1, 2006 - 2:07 AM) [snapback]428471[/snapback] starting fluid. yeah to see if maybe my fuel pump crapped out before i started pulling stuff apart. -------------------- 94 st
May 1, 2006 - 11:44 AM |
QUOTE(Speedball-OD @ May 1, 2006 - 1:48 AM) [snapback]428481[/snapback] The belt should only have about 1/4" to 1/2" of play in it. Your starting issue may be a result of the belt jumping a tooth or two because of the loose issue or the belt has stretched out over time and simply needs to be tightened back up. Check to see that the timing is correct by lining up the crank pulley at TDC (the mark on the balancer should be right on zero) and the cam pulley mark is at the 12 o' clock position. Look through the small inspection hole on the cam pulley spoke and you should see an indentation on the 1st exhaust cam bearing cap through the hole. The proper cam bearing mark is the one thats most towards the front of the vehicle (if there are two marks on the cap) hey yeah thats what i am thinking....at least i hope that is all that it is. thanks for the timing mark info as this is my first time doing a dual cam. also it has a lot of play i'm gonna get a new belt and possiblt the idler/tensioner too. -------------------- 94 st
Lo-Fi Version | Time is now: November 30th, 2024 - 4:52 PM |
