> Anybody know this CAI
post May 1, 2006 - 10:42 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
so ive seen this on ebay and want to know if theres anything wrong with it
it looks exactly like an evilspeed dr.cai but its like $70 cheaper
its the only place ive seen [other than evilspeed] that sells pre-made cold airs or 6gens and its on ebay...i figure there must be something wrong
I <3 Dustin---07/16/06
post May 1, 2006 - 10:45 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
dont buy any cai for more than 40 bux...if you want to buy a cai, ill sell you a setup. but i still recommend the drop in cai, remove bottom reservior sonce you gotta remove it anyways. drop in a k&n filter and waa laa
post May 1, 2006 - 10:48 AM
LimitedST
Joined Jan 7, '06
From arizona
QUOTE(LewFX @ May 1, 2006 - 10:45 AM) [snapback]428566[/snapback]
so your saying, dont buy sumthing like a injen or Type R CAI/Short ram?
why?
post May 1, 2006 - 10:49 AM
LewFX
Joined Jan 28, '05
unless you get it for 50 bux...no! why not go to a muffler place and have them bend you a cai or short ram for 40 bux, powder coat it and put on a apexi filter!
This post has been edited by LewFX: May 1, 2006 - 10:56 AM
post May 1, 2006 - 10:53 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE(LewFX @ May 1, 2006 - 11:45 AM) [snapback]428566[/snapback]
isnt that just a short ram?
post May 1, 2006 - 10:58 AM
LewFX
Joined Jan 28, '05
no its not a short ram, its not really a cai, its more of a medium-cold intake, it gets cold air thru the fender and still looks stock.
post May 1, 2006 - 11:02 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE(LewFX @ May 1, 2006 - 11:58 AM) [snapback]428573[/snapback]
lol....you must explain...im intrigued
post May 1, 2006 - 11:06 AM
LewFX
Joined Jan 28, '05
due to the bottom reservior your stock intake doesnt get all the air that it should, if you remove it, more air flows into your intake and with a k&n filter that flows better than stock filters, you will get more cold air.
the stock reservior has 4 small holes drilled on the bottom, you tell me if you get enough air. what a cai setup with piping does is similar, except the filter goes into the fender getting air faster which is good but the throttle response is a tad bit longer.
Lo-Fi Version Time is now: January 9th, 2025 - 7:26 AM
