> left rear tire is wobbly???
post May 1, 2006 - 10:14 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
well i just got done doing my rear disc brake shoes then...at first when i started driving the car...it was fine..after celaning up and changing..got into the car and went for another test drive...thats when i heard a huge cluck...i didn't mind it untill going forward..kept hearing the cluck but thought it would go away then as i started going faster the left rear wheel started to wobby then the sound got louder!!!! could it be the wheel bearing or should i just start riping everthing apart and start at zero to see if i could figure out the problem...
post May 1, 2006 - 10:51 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
start over and make sure nothing is loose, that happened to me when i changed back to some old brake pads, put some newer ones on, noise went away. its not a bearing...is your ebrake down? check everything again, if you want do the bearing test.
post May 1, 2006 - 11:24 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
well yeah i had no e-brake..thats why i changed the rear shoes...now i finally do..i think it might just be loose parts..but yeah i haven't try putting new pads in yet just waiting to put in cross drill and better pads....
post May 2, 2006 - 12:50 AM
blu94gt
Joined Mar 23, '05
From Kansas City
did you tighten the lug nuts right? sometimes they can be dumb
1999 Celica GT
post May 2, 2006 - 6:31 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
If you've had the disk off then you maybe haven't got it back on squarely so its jamming on the pads as if it was warped (one of my rears is warped only by 1mm yet once it heats up the brake fluid enough and the brakes start to jam on then the full car can seriously
judder about).
Could be one of the bushes from the suspension that has been ok upto now, but as you've jacked it up its moved it a bit and freed it off so it now allows the hub to move.
I would definitely not drive it until you've found out what it is, if it is your disc and it is sticking then continual driving will end up warping it like mine.
If its anything else then driving it could have worse effects.
Dan
post May 2, 2006 - 6:36 AM
Rayme
Joined Feb 18, '06
From NB, Canada
a badly adjusted ebrake system can make your rear wheel feel wobble and make a thumping noise, it happened to me! I swear the wheel was about to fell off...
-Rémy
02 SiR, 08 250R
post May 2, 2006 - 9:21 AM
fastcelica20
Joined Apr 4, '06
From Minnesota
yeah when i installed new ebrake shoes they were doing that that's why i took it off and took it to the shop. they said "it was loose" but i tightened everything. so check to see if everything is good and tight. if u need help holler at me. im in stp too
post May 2, 2006 - 10:44 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
thanks guy that might be the problem..yeah rayme the wheel feels as if it was going to fall off...yeah and ill give a holla fastcelica 20...this thrusday that the only time i have off work...but il give it a try again today taking the e-brake system off and redoing everything...
post May 2, 2006 - 9:16 PM
fastcelica20
Joined Apr 4, '06
From Minnesota
yeah after 6pm just holla at me if you still need help. thats when im done with work
post May 4, 2006 - 12:05 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
ok figure out the problem..my left rear e-brake line is stuck it wont retrack..like go back to normal or loosen up..man what do you guys think i should do..the ebake line is in perfect condition..how could i loosen the line up..or get it back to normal...
post May 4, 2006 - 1:12 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
I assume by ebrake you are talking about the handbrake?
Cos, my rear caliper is sticking too I think (not my handbrake that is ok), anyone with advice for sorting out both problems?
Lo-Fi Version Time is now: February 21st, 2025 - 5:04 PM
