![]() Enthusiast ![]() Joined Nov 7, '05 From Brisbane, Australia Currently Offline Reputation: 0 (0%) ![]() |
hey all,
as the title says, i'm looking for a very mild cam upgrade and thought of the ZR model that's here in australia, it also has the 5SFE engine, so i was thinking, would it be possible to change the stock SX cams, to the ZR ones, without any dramas? thanks in advance |
Enthusiast ![]() ![]() Joined Dec 8, '04 Currently Offline Reputation: 0 (0%) ![]() |
Both the SX and ZR have 5S-FE engines? If they do then you won't have problems swapping cams, but you won't gain any power since they're the same.
QUOTE(BLADDER_MASTER @ May 4, 2006 - 10:10 AM) [snapback]429694[/snapback] Both the SX and ZR have 5S-FE engines? If they do then you won't have problems swapping cams, but you won't gain any power since they're the same. i just read somewhere on here that they do. the ZR is supposedly the sportier version, where the SX is just base model camry spec... |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 25, '05 From Sydney, Australia Currently Offline Reputation: 0 (0%) ![]() |
The SX and ZR have both got the same engine.
So therefore the it wont make any difference if you are swapping the cams from the ZR to the SX. They are both 100Kw and 196 Nm torque. The only difference is the standard options between the 2 ![]() -------------------- ![]() 98 ST204 ZR - Black Beauty - Roaming the streets of Sydney 73 TA22 LT - Tiffany Blue - Mint Classic Weekend Cruiser 75 TA22 LT - Snow White - Mint Classic Weekend Cruiser 77 RA28 LT - Flubber Green - Mint Classic Weekend Cruiser 94 MX-5 NA8 Clubman - Red Racer - Looking for corners WIP Project: 69 RT40 Corona, 2nd WIP Project: 66 RT40 1600s Corona 86 Corona RT142 - Daily Driver 6GC 4 Life Baby!!! |
oh
![]() ok then oh ![]() ok then someone can close this then ![]() |
Lo-Fi Version | Time is now: February 22nd, 2025 - 10:03 PM |
