My Auto to Manual Swap IS DONE, finally! |
Aug 11, 2006 - 9:30 AM |
Don't tell them anything, there shouldn't be any problems at all.
if they bring anything up to you, just tell them you put a new ECU in because yours crapped out -------------------- |
steff, it shouldnt effect anything, theyre both OBDII ecus.
13.6@108MPH, 5SFTE Powered |
Aug 11, 2006 - 9:37 AM |
I'm not telling. Hopefully the ECU doesnt say anything either and we shouldn't have a problem I don't know what info comes up when they plug in the OBDII
I've just always been nervous when I get my car inspected since they failed me the first time for something as stupid as a hole in the headlight. I'm not worried about the way it runs. I love my franken-car the way it is This post has been edited by hurley97: Aug 11, 2006 - 9:48 AM -------------------- |
Aug 11, 2006 - 10:36 AM |
Enthusiast Joined Oct 5, '05 From NE Currently Offline Reputation: 6 (100%) |
congrats on the swap. And hope you like the feeling of shifting. Its very fun lol. But the OBDII should be ok.
Aug 11, 2006 - 10:50 AM |
Enthusiast Joined Jun 29, '03 Currently Offline Reputation: 0 (0%) |
Grats on the swap. All those pics...reminds me of when I did my manual conversion... what a PITA. The big hole for the master cylinder.... how did you manage to get such a clean hole? I had to drill a bunch of holes and then hammer it out.
Aug 11, 2006 - 11:15 AM |
QUOTE(Chanh55 @ Aug 11, 2006 - 11:50 AM) [snapback]467842[/snapback] Grats on the swap. All those pics...reminds me of when I did my manual conversion... what a PITA. The big hole for the master cylinder.... how did you manage to get such a clean hole? I had to drill a bunch of holes and then hammer it out. thanks! Manny + 1-1/4" Holesaw + Dremel This post has been edited by hurley97: Aug 11, 2006 - 11:16 AM -------------------- |
Aug 11, 2006 - 11:30 AM |
Enthusiast Joined Dec 16, '02 From New York Currently Offline Reputation: 4 (100%) |
congrats Steff
-------------------- Buy my Celica $2,500 - http://www.6gc.net/forums/index.php?showtopic=76562&st=0
Aug 11, 2006 - 12:31 PM |
Enthusiast Joined Jul 28, '06 From Delaware Currently Offline Reputation: 0 (0%) |
QUOTE(hurley97 @ Aug 11, 2006 - 11:15 AM) [snapback]467849[/snapback] Manny + 1-1/4" Holesaw + Dremel 1 1/2" holesaw bits are fuuuunn, you know, except when it catches and either slaps you across the face with the cord or tries to break your wrist |
Aug 11, 2006 - 1:00 PM |
Enthusiast Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) |
wheeeee 5speeds. but 4 days, and 1000 bucks? shheeeeeeeeesh... way too long, and way too much. but kudos steff.
Aug 11, 2006 - 1:36 PM |
Enthusiast Joined Nov 23, '05 From Charleston, WV Currently Offline Reputation: 1 (100%) |
Great job. I did the same project. I love it. I'v got just GT shifter cabels, but they work just fine. Big difference between auto and stick. So much fun, faster and ju can do burn out if you want...( I don't do that)
Do you guys know what is a diff in pouds between auto tranny and 5 speed. I think it's pretty big. |
Aug 11, 2006 - 2:04 PM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
QUOTE(miro1975 @ Aug 11, 2006 - 6:36 PM) [snapback]467900[/snapback] Great job. I did the same project. I love it. I'v got just GT shifter cabels, but they work just fine. Big difference between auto and stick. So much fun, faster and ju can do burn out if you want...( I don't do that) Do you guys know what is a diff in pouds between auto tranny and 5 speed. I think it's pretty big. I think around 75 lbs or so. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Aug 11, 2006 - 2:11 PM |
yea, the auto tranny is alot heavier compared to the manual.
john, it only took 4 days because of missing and wrong parts. in reality, i could have done the swap in a full days work. we broke off early on saturday cause i had already worked in the AM, so we worked a couple hrs, and called it a day so i could eat. sunday, there really wasnt much to do other than install the clutch line, once we knew the TOB wasnt right. monday was a dead day, we didnt touch the car. once we got the parts on tuesday late morning, the car was back up and running in a matter of a couple hrs. so, total time was prolly 6-8 hrs..by far no records were broken, but that wasnt the goal. enjoying the car steff? -------------------- Former Team 5SFTE pro member ;)
Aug 11, 2006 - 2:21 PM |
that auto tranny is massive. I have all this room in my engine bay now...hmmm....what to do with it
and yes, I'm enjoying the car very much! It was well worth the money and time I got to spend with you guys -------------------- |
Aug 11, 2006 - 2:42 PM |
oh i realize there wasn't a speed record in pursuit. just seems like a terribly long time. i completely understand though, as 10min jobs have turned into day long jobs for me too. don't think i meant it like that. and the money, just don't spend 1k on the rear disc conversion steff. .
Aug 11, 2006 - 7:55 PM |
QUOTE(hurley97 @ Aug 11, 2006 - 9:23 AM) [snapback]467822[/snapback] I'm just wondering if it will affect anything when I have to get the car inspected. Will it give them different info? Will it tell them its a 96 while my registration says 97, maybe they'd have a problem with that? Should I get Jeff's 97 ECU just to be sure or do you think I'll be perfectly fine? So far it's been starting/running fine... no problems, no check engine light. Dont' worry too much about it. There are basically 2 reasons for the different part #. Either Toyota decided after production to change some of the programming inside, and the 97 is one of these newer ones, or Toyota decided during production [for the 97 model] to change it. I will TRY to remember [and get a chance] to check for any TSBs on it at work tomorrow. -------------------- |
Aug 14, 2006 - 8:50 PM |
A day late.
Sorry. But anyways, there are no TSBs on it. The only other thing I can do right now is check the p#s and see if the 96 one is revised in later models. If you still car, get me the p#. Or not. -------------------- |
Aug 20, 2006 - 11:08 PM |
Enthusiast Joined Jun 25, '06 From Bremerton, Washington Currently Offline Reputation: 1 (100%) |
manual is so much fun to drive how much did you spend to get it done/, my friend wants to convert his galant to a manual transmission good work though
Aug 20, 2006 - 11:21 PM |
Enthusiast Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
i bet you felt like a kid in a candy store with so many skilled people helping you out haha.. id feel like a celebrity if those guys worked on my car
This post has been edited by brianforster: Aug 20, 2006 - 11:21 PM |
Aug 21, 2006 - 3:14 PM |
QUOTE(rayneezy23 @ Aug 21, 2006 - 12:08 AM) [snapback]471030[/snapback] manual is so much fun to drive how much did you spend to get it done/, my friend wants to convert his galant to a manual transmission good work though in the end it cost about $1k. I bought parts here and there so it didnt seem like that much money. it was well worth it to me cause I really like my car and intend to keep it for as long as possible. ...it's so much more fun to drive and the gas mileage is soooo much better -------------------- |
Aug 21, 2006 - 3:19 PM |
QUOTE(alltracman78 @ Aug 14, 2006 - 9:50 PM) [snapback]469049[/snapback] A day late. Sorry. But anyways, there are no TSBs on it. The only other thing I can do right now is check the p#s and see if the 96 one is revised in later models. If you still car, get me the p#. Or not. thanks Jeremy. the one thats in my car now is p# 89661-2D450 the 97 A/T ECU (from the EPC) is p# 89661-2D870 you can check if you have time/remember... no rush, everything works This post has been edited by hurley97: Aug 21, 2006 - 3:55 PM -------------------- |
Lo-Fi Version | Time is now: November 30th, 2024 - 4:47 AM |
