Enthusiast ![]() ![]() Joined Aug 14, '04 From Toledo, Ohio Currently Offline Reputation: 0 (0%) ![]() |
So i installed the front pair of springs on my car yesterday and when i went to take a test drive, the car wouldnt move. i put it in gear and looked under the car and the passenger side axle is just spinning. no grinding sound or anything, just spinning.
if it makes any difference, i have a 3s swap with the alltrac axles and i did the "short axle" fix. my only thought is that i pulled the axle out of the wheel hub. any thoughts? the car looks great just sitting there. lol |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) ![]() |
yup, definitely sounds like you didn't put both the axles back in the hubs, that's pretty much the ONLY thing that could cause your problem
-------------------- 1999 Celica GT
yeah i got a chance to look at them today and its definately the problem
ok im home from work and im trying to get this back together, but im having a hard time...do i just need to push the axle back into the hub?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) ![]() |
QUOTE(gtfc115 @ May 5, 2006 - 3:05 PM) [snapback]430538[/snapback] ok im home from work and im trying to get this back together, but im having a hard time...do i just need to push the axle back into the hub? put the axle back into the hub, make sure the splines go in, and then put the axle nut back on it. i take it you didn't do your own swap? -------------------- |
no i didnt do my own...and im pretty sure i fixed it. thanks
Lo-Fi Version | Time is now: February 13th, 2025 - 3:05 PM |
