3 Pages V  < 1 2 3 >
> swap officially finished! (but still has minor probs), i just drove it.. WOOOO HOOO!
post May 7, 2006 - 6:32 PM
Hanyo
Joined Aug 16, '03
From Bay area
did you cover that hole on your down pipe?
Is your inter-cooler piping touching the exhaust manafold?
post May 7, 2006 - 6:49 PM
jcbass7
Joined Apr 20, '06
From Florida
oh yea hanyo has a good point. If that hole isn't covered i'd guess that the hot air blowing out against the hood would make it pretty hot
post May 7, 2006 - 7:41 PM
didn't i say you needed to close that o2 sensor hole?
might wanna hop on that really fast
post May 7, 2006 - 7:56 PM
BBoYRuGGeD
Joined Jun 4, '04
From Northern New Jersey
congrats on the swap man! smile.gif hope you get all them minor issues sorted out asap w/o a problem
btw that IC piping up top seems pretty close to you exhaust manifold man...u might wunna move it away a lil
bboy
post May 7, 2006 - 7:58 PM
it gets hottest right over the tubular manifold
yeah, that pos manifold will make more heat and dosnt have a heatsheild, like the stock one. so yeah, i would imagine it gets very hot there.
can you use usendit.com to upload the videos? that site u used recompresses the vid into a pretty bad quality
post May 7, 2006 - 8:19 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
ill compress the vid
post May 7, 2006 - 9:40 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
if you notice both of the studs are broken on that hole, chuckys dad said he has easyouts at work so as soon as he brings those home im putting in new studs + my o2 sensor, im hoping this will resolve some of the problems.
and no that 45 degree out of the TB does not touch the manifold, and will have even more clearance when i get the stock manifold from yungazzdriver, although i am thinking about going 90 degree out of the TB because that pipe gets real hot as it stands right now
post May 8, 2006 - 12:24 AM
you can keep it where it is and wrap it with exhaust wrap if you want. that will fix the problem
post May 9, 2006 - 9:29 PM
f1yen
Joined Oct 29, '05
From Muskego, WI
[font=Tahoma]so is your car still idling high?, because i have had this problem b4, check the little throttle stop thing that will stop your throttle from chokin itself out, if that is a little out, it will give you the symtoms of it idling high, and decelling slowly, if its not that, have a person turn on the car, then cover the whole throttle body, with your palm of your hand, if it still runs, you have a leek somewhere. one one car i had redone the seals, the throttle body seal was slightly different from top to bottom, i had it upsidedown, and it had a small leak, it will idle high and rev down slowly, it also stayed running with the hand over the throttle body. something to think about wink.gif
i wish i was "flyen"
post May 10, 2006 - 12:32 AM
QUOTE(f1yen @ May 9, 2006 - 10:29 PM) [snapback]432188[/snapback]
you know the car will still run even if you cover the throttle body with your hand....that doesn't tell you anything...if it does shut off you got a problem..
that and you know you can't touch a TB inlet on a turbocharged car...IC pipe is in the way..and go ahead and try to stick your hand into a turbo, haha that'll be fun wink.gif
This post has been edited by playr158: May 10, 2006 - 12:33 AM
post May 10, 2006 - 11:04 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
plus 2nd gen engine will not run without the AFM in the loop
post May 10, 2006 - 12:43 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
good job bryan!! im glad everything worked out! who woulda knew you would get the car running so quick!! imma tell my boys to look at the vids asap...show them what a BEAST looks like...(the vids arent pulling up on this comp, but when we have our meet tonight i'll tell them about it!)
post May 12, 2006 - 7:47 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
it ended up being the throttle cable was too tight, and was mounted a little crooked so it was too tight + leaned to the left, after installing DG's bracket and loosening the cable it idles at 1100-1200 now sounds MUCH better and most of the problems seemed to be because of it (shaking when turning the car off)
once it warms up it starts to go down to 800-900 and then i think its not getting the o2 readout so it pulls back up.
still have a power steering leak, that will be fixed tomorrow hopefully.
what temperature is the 3sgte thermostat? how much diff from the 7afe one? because my temp gauge in the car barely reads higher when its warmed up, we tested the sensor and it does work, my friends just assume its because the 3sgte has a higher temp thermostat.
post May 12, 2006 - 10:02 PM
morbiddelusions
Joined Mar 19, '06
From augusta ga
lookin good
This post has been edited by morbiddelusions: May 12, 2006 - 10:07 PM
94 st
post May 12, 2006 - 10:19 PM
the temp gauge should sit around the middle when warmed up .
if you going to replace it, make sure u get a brand new toyota one with a new gasket.
post May 13, 2006 - 12:18 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
what needs to be replaced the gauge or the thermostat?
post May 13, 2006 - 12:57 AM
QUOTE(brianforster @ May 13, 2006 - 1:18 AM) [snapback]433462[/snapback]
i dont really know what your seeing... but based on what you said i guess the thermostat.
post May 13, 2006 - 9:08 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
how long should it take to reach the center?
post May 13, 2006 - 12:31 PM
Rjb23
Joined Feb 8, '04
From KY
Depends when I first did my swap it took for ever for it to reach the center. Now it takes about 5 mins or so.
post May 13, 2006 - 2:01 PM
BBoYRuGGeD
Joined Jun 4, '04
^^^ yap same...about 5 min or less with mine on a nice warm day. anywhere from 5-10 min when its cold out.
bboy
3 Pages V  < 1 2 3 >
Lo-Fi Version Time is now: February 22nd, 2025 - 12:14 AM
