quite a few electronic accessories do not work, but its not a fuse :frown: |
May 6, 2006 - 6:53 PM |
Enthusiast Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
ok so the following things do not turn on/work in my car:
passenger window (drivers side window works, and passenger door lock/power mirror works) radio clock dome light door ajar buzzer probably other things i havent found out about yet its not a fuse, i checked, im afraid i might have really fudged something up.. i accidentally put the battery cables on backward and blew the main fuse, replaced that and everything else works, so im afraid i screwed something up because when dan was here helping me put in my airbags/new dash/power windows he tested all that stuff and it worked.. any ideas guys? |
May 6, 2006 - 10:38 PM |
if it isn't any fuse (in the bay and the interior) you might of blown the voltage regulator in the alternator.
May 6, 2006 - 11:41 PM |
Moderator Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
Check the plugs behind the door panel. You might have forgot to plug something back in. Also double check the three interior plugs next to the ECU
-------------------- I will return one day. |
May 7, 2006 - 5:10 AM |
if my alternator was messed up wouldnt i have a battery light?
im pretty sure all the plugs are in because they worked at one point, thats what scares me the most This post has been edited by brianforster: May 7, 2006 - 5:11 AM |
May 7, 2006 - 8:56 AM |
Enthusiast Joined Nov 12, '02 From Baltimore, MD Currently Offline Reputation: 1 (100%) |
QUOTE(defgeph @ May 6, 2006 - 11:41 PM) [snapback]430987[/snapback] Check the plugs behind the door panel. You might have forgot to plug something back in. Also double check the three interior plugs next to the ECU Are you talking about the 3 on that metal bracket? If so, I remember plugging those in yesterday. Nothing changed. This post has been edited by bojangles_8686: May 7, 2006 - 8:56 AM -------------------- |
May 7, 2006 - 10:49 AM |
it ended up being an engine bay fuse that was labeled as X but was blown, replaced it and everything works now except the passenger window and the horn, i found the horn wasnt hooked up up front , but it wasnt long enough (is the horn in a diff spot on an st vs a gt?) so i extended the plug and it doesnt work still, but the horn relay in the engine bay clicks every time i press the horn down
anyone have any idea why my pass window isnt working and now the horn? |
May 7, 2006 - 11:12 AM |
QUOTE im pretty sure all the plugs are in because they worked at one point, thats what scares me the most you cant be "pretty sure" when working with electrical stuff. you have to go back and check ten times. a lot of times you just forget to plug something back in and it causes a lot of strange issues. -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 7, 2006 - 11:30 AM |
everythings plugged in now
Lo-Fi Version | Time is now: November 27th, 2024 - 11:37 AM |
