> Car Won't Start, Engine doesn't turn over
post May 7, 2006 - 12:33 AM
hellsyphon
Joined Dec 3, '04
From torrance, ca
Hey everyone, I don't know where this would go since I do not have a celica anymore, but my MPV died tonight in the parking lot. When I turn the key to crank the engine over... there is only a click and nothing else. I still have electrical power as my headlights and interior lighting work, but the car does not turn over at all or even attempt to. The only noise is a one single click and some really low pitch squeeling noise that kinda sounds like sloshing buzz. I'm thinking its the distributor or alternator? Any feedback would be greatly appreciated.
-Gia.
post May 7, 2006 - 12:53 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
loose battery cable or a corroded connection/cable is the likely culprit.
post May 7, 2006 - 12:57 AM
hellsyphon
Joined Dec 3, '04
From torrance, ca
I know the battery cables are on nice and tight, but guess I'll have to go out and check tomorrow morning when theres enough light. Could there be a grounding problem too? As the battery has died twice and right now its on a fresh battery and once there was voltage surge that caused my radio faceplate to melt. Could that also do something?
post May 7, 2006 - 12:18 PM
tin_foil
Joined Jun 7, '05
From Corvallis, OR
could be half a dozen thing. It could be a loose battery cable, but usually it keeps clicking as long as you've got the key turned. But just go through it systematically. Check if it's a fuse. Then see if there's juice getting to the distributor. Then see if the plugs are sparking. If you haven't found your problem by then put a little fuel in the cylider and see if it fires. If it does, it might be fuel pump.
post May 7, 2006 - 2:18 PM
hellsyphon
Joined Dec 3, '04
From torrance, ca
well thanks for the help everyone i figured out that it is the starter
post May 7, 2006 - 4:29 PM
celicarus
Joined Jul 5, '05
From Arlington, TX
QUOTE(Bitter @ May 7, 2006 - 12:53 AM) [snapback]431007[/snapback]
this was my problem a few wks ago -- had to clean up the battery terminal - after that it was fine
Lo-Fi Version Time is now: November 23rd, 2024 - 10:02 AM
